Another ? about (auto) Trany temp gauges
Old Oct 24, 2006 | 10:17 AM
kingdog's Avatar
kingdog
Default Another ? about (auto) Trany temp gauges
I have heard/read that there are different locations for the temp sensor for trany temps, I think ( IMO ) that if there is an inline before the trany cooler that this would be the best one.
What do you have and where does the sensor mount?
Any and all opinions welcomed on this on please.
Thanks
Ralph
Old Oct 24, 2006 | 01:35 PM
DBLR's Avatar
DBLR
Default RE: Another ? about (auto) Trany temp gauges
I too have been told to install it in the line going to and some where before the tranny cooler. How it's done or if they make a part to fit in line I have no clue. Maybe the minds will have some idea once they awake from their nap.
C.
Old Oct 24, 2006 | 02:47 PM
Drew's Avatar
Drew
if I remember there is a 'T' in the line leading to the tranny from the cooler or to the cooler, cant remember, that a probe can be screwed into to see the temp of the fluid.
Old Oct 24, 2006 | 08:59 PM
Nelspruitdodger's Avatar
Nelspruitdodger
Have a look at this, it is an oem cooler linewith a fitting for a tranny temp sender port.
http://dieselmanor.com/dm_products/DM-CLG3.asp
Definately what I will be using
Old Oct 24, 2006 | 09:24 PM
steve05ram360's Avatar
steve05ram360
or like this? have to adapt the lines but you can put it in-line with the tranny cooler lines.
http://www.autometer.com/cat_accesso...l.aspx?vid=169
Old Oct 24, 2006 | 11:52 PM
DieselDemon's Avatar
DieselDemon
Doesn't the tranny have spare port on the passenger side, above the pan. I could swear I have seen one on every single tans I've been under.
More than likely, I'm wrong..........
Good luck.
Old Oct 25, 2006 | 03:14 PM
jrlaidle's Avatar
jrlaidle
So if you did put the sending unit inline of the supply side to the cooler, what would be the max temp you would be comfortable seeing?
Old Oct 25, 2006 | 08:33 PM
DieselDemon
Depends on how high it gets. My old tranny used to climb to 220 when pulling hard. My new tranny and tc haven't climbed above 195 out of lock up yet. In lockup I am seeing temps of 110-120 on the highway and 130-140 around town.
If you hit the cooler line on the way TO the cooler, that is a good place to monitor.
Good luck.
Old Oct 25, 2006 | 09:47 PM
kingdog's Avatar
kingdog
ORIGINAL: Nelspruitdodger
Thanks for posting that link, I will be ordeing one of them setups for sure.
Ralph
Old Oct 25, 2006 | 11:23 PM
Nelspruitdodger
- pleasure, I like to keep that oem "look", as far as the SM at local dealer is concerned.
BTW, nice ride!
