Help, might be getting 1st gen CTD!!!
Old 10-30-2006, 07:01 PM
ryan10's Avatar
ryan10
ryan10 is offline
Default RE: Help, might be getting 1st gen CTD!!!
Well its official. Im buying it!!! I will be going back up saturday morning to look it over once more, and then i will be getting it. Any last things to look for? Any thing to feel for when i drive it. The final price will be 2150 including a 100 mile delivery. Im so pumped. What are some final things that i should look for? Also, what can i do for mods. I would really like to lift it a little, but not sure if you can because its a 2x4. How will this do towing my 86 k10, and a bobcat?
Old 10-30-2006, 08:41 PM
f0x672's Avatar
f0x672
f0x672 is offline
you will do just fine towing both those things... cummins are ment to get abused. my buddy had a 93' ram 250 with a cummins in it, crashed it right into a tree doing 35 mph, knocked the engine clean off the mounts and snapped the bell housing on the transmission... i dont know how but that engine still fired up and ran fine after the accident... insane stuff... your getting a good buy with that beast
Old 10-30-2006, 08:52 PM
ryan10's Avatar
ryan10
ryan10 is offline
Thanks a lot, I am so pumped, this is going to be a long week having to wait until saturday to get my new rig.
Old 11-03-2006, 09:12 AM
ryan10's Avatar
ryan10
ryan10 is offline
Well I am going to look at teh truck one last time tomorrow, its supposed to be cold out, around 35 degrees. How should the truck start in this weather?
Old 11-03-2006, 11:35 AM
dodgedakotacrazy's Avatar
dodgedakotacrazy
dodgedakotacrazy is offline
it'll start fine....it'd be better if it was plugged in for a couple hours. also...i'd at some anti gel to the fuel. I turned the pump up on mine and ran a single 3.5 in straight pipe. and i can get a 4th gear scratch out of it..where are you located?? we might have a cab forsale.
Old 11-03-2006, 03:21 PM
Mayfair's Avatar
Mayfair
Mayfair is offline
I don't think I'd say that the rust spot on the roof was "common" at all. As a matter of fact, I don't think I've ever seen a Ram with a rust spot up there.
hmmmm ...
No biggies though. It sounds like you've got both the cajones and the time to fix it up so go for it. I agree with the previous poster about the trans though. That would probably be my biggest concern.
oh well ...
Enjoy the hell out of it Ryan!! I think you picked a GREAT first car / truck !!
Old 11-03-2006, 07:31 PM
ryan10's Avatar
ryan10
ryan10 is offline
I am in MA
Old 11-04-2006, 12:07 AM
dodgedakotacrazy
Oh..to far away to sell a cab. and as far as the roof rust on the cab i have one that has rust up there...basically surface rust though....but alittle surface rust can turn into big rust...
Old 11-05-2006, 02:56 AM
ryan10's Avatar
ryan10
ryan10 is offline
OK, thanks. I want to lift it a little, even though it is a 2x4. Is there any coil springs, or spacers that i can get to work on it? Also, can i modify a body lift to make it fit for a diesel?
Old 11-08-2006, 09:58 PM
ryan10's Avatar
ryan10
ryan10 is offline
well, i finally drove my truck on an actual ride, and now i can say that i know what you guys are talking about when you talk about cummins power! The only mod is the pump turned up, How much TQ does this add? I pulled my 4 wheeling truck around, and i couldnt even tell it was on the back.
For my first mod, i am going to lift it a little. I plan on installing a ring-type coil spring spacer from JC Whitney. This is all i could find for the front. Is this the only option? Also, since it is a D250 would D350 coils up front make any difference? For the rear, i am going to use a 3" block, and i am going to modify my intercooler lines so i can run a 3" body lift. Who has put the body lift on their truck, and how hard was it? what shocks should i run? With this setup can i run 33" tires?
