24 valve cummins vs 12 valve cummins
Old Oct 30, 2006 | 11:53 PM
dvcap2004's Avatar
dvcap2004
Default 24 valve cummins vs 12 valve cummins
what year did they stop putting the 24 valve cummins in the dodges? what would be a better, more reliable, and more powerful engine a 24 valve or the 12 valve?
Old Oct 31, 2006 | 12:00 AM
jakebrake's Avatar
jakebrake
Default RE: 24 valve cummins vs 12 valve cummins
12v to 24v was midway through 1998, 24v isb to 24v common rail was in 2003. You can build massive amounts of torque from the old 12v. Their injection pumps are a little more robust. How ever fuel mileage is lower with the 12v. The 24v's are electronic, so if you want more power, all you need is a chip. As for which is better, I have no opinion. I like the old 12v's because of no electronics. I like the new 24v's because of fuel mileage and the transmissions offered behind them.
Old Oct 31, 2006 | 12:01 AM
CowboyBob's Avatar
CowboyBob
They started putting the 24v in the 98.5 year model. The 12v is more mechanical (such as the injector pump), the 24v is more computer controled.
dvcap2004's Avatar
dvcap2004
which one has more h.p.? the 12 valve or the 24 valve?
Old Oct 31, 2006 | 12:06 AM
sharx ram's Avatar
sharx ram
The 24 has more power than the 12, My buddy has a 12 and mine spanked him stock.
Old Oct 31, 2006 | 12:16 AM
dvcap2004's Avatar
dvcap2004
but i thought that the brand new cummins were 12v?
Old Oct 31, 2006 | 12:41 AM
jakebrake's Avatar
jakebrake
They are still 24 valves. just use a common rail to feed the injectors
Old Oct 31, 2006 | 10:54 AM
Drew's Avatar
Drew
89-98.4 were 12valves, 98.5-present are 24valve
there was an injector pump change in 94
head redesign and injector pump change in 98.5
injection system and a slight block redesign in 03
in 07.5 the 5.9L ISBe will be dropped all together for the 6.7L. I;m unsure of the designation of the engine right now.
