All about the Powerful 6.7-liter Cummins
Old Nov 1, 2006 | 10:30 AM
htgriffith's Avatar
htgriffith
Default All about the Powerful 6.7-liter Cummins
Found this and thought I would pass it on...........
Dodge Introduces Cleaner, Quieter and More Powerful 6.7-liter Cummins Turbo-Diesel Engine at State Fair of Texas
Engine available in January on new 2007 Dodge Ram 2500/3500 models
* Increased output with 350 horsepower and 650 lb.-ft. of torque * New, fuel-saving six-speed automatic transmission features best-in-class gear-ratio spread; standard Electronic Range Select (ERS) * First-ever integrated exhaust brake available direct from the factory * 50-percent quieter engine; 3 Dba reduction in cabin sound levels * Life-to-major overhaul intervals of 350,000 miles, providing more than a 100,000-mile advantage over the competition
DALLAS, Sept. 28 -- The war among America's diesel- powered pickup trucks rumbles into a new round with Dodge announcing more horsepower, torque, refinement and a host of advanced towing features.
Today at the State Fair of Texas, Dodge will reveal more details about the 2007 Dodge Ram Heavy Duty's new 6.7-liter Cummins turbo-diesel engine, which replaces the current 5.9-liter engine. Producing 350 horsepower at 3,000 rpm and 650 lb.-ft. of torque at 1,500 rpm, the 6.7-liter engine features an all-new six-speed automatic transmission that delivers improved fuel economy and performance.
The engine will be available in 2007 Dodge Ram 2500 and 3500 models beginning January 2007. A commercial-use 6.7-liter Cummins turbo-diesel engine was introduced in early 2006 with the all-new Dodge Ram Chassis Cab, which is available now.
"The 2007 Dodge Ram Heavy Duty's new 6.7-liter Cummins turbo-diesel engine sets the performance standard with an outstanding combination of horsepower, torque, refinement and emissions-reducing technology," said Scott Kunselman, Chief Engineer - Dodge Ram. "Providing superior trailer towing, acceleration, throttle response and drivability, the new 6.7-liter engine is not only more powerful, it's also cleaner with B5 biodiesel compatibility and a reduction in particulates and nitrogen oxide (NOx) that comply with the 50-state 2007 heavy-duty emission standards."
Based on the proven DNA of the 5.9-liter Cummins turbo-diesel engine, the new 6.7-liter engine is 50-percent quieter, while featuring a 107mm bore by 124mm stroke (versus 102mm bore by 120mm stroke for the 5.9-liter engine). The new engine retains more than 40 percent of its components from the 5.9- liter engine and shares more than 80 percent of its components with the new Dodge Ram chassis cab.
The high-performance 408-cubic-inch inline-six intercooled turbo-diesel is clean and quiet, and meets all 2007 U.S. federal and state emission requirements, which require a 90-percent reduction in particulate matter and 50-percent reduction in NOx.
Offered for the first time in Dodge Ram Heavy Duty trucks are features including an integrated exhaust brake, standard Electronic Range Select (ERS) and "Smart" tow/haul controls that provide customers flexibility and increased safety when towing heavy loads.
Improved Performance, Durability and Emissions
Dodge Ram Heavy Duty's new 6.7-liter turbo-diesel engine features improved performance, durability and significantly reduced emissions.
Enhancing diesel-powered performance of 2007 Dodge Ram Heavy Duty trucks is an electronically-controlled Variable Geometry Turbocharger (VGT), which precisely matches boost pressure with the engine's needs. The 6.7-liter engine's VGT utilizes 16 fixed vanes and a sliding yoke, providing variable geometry, as well as an electric valve. The VGT produces optimum combustion control, reduced emissions and a quiet and lag-free throttle response.
Decreasing NOx emissions is a next-generation cooled Exhaust Gas Recirculation (EGR) system. The Cummins 6.7-liter engine's EGR system is water cooled, with the air reintroduced into the intake system, keeping turbo and intercooler components clean, which increases the engine's durability.
Within the 6.7-liter Dodge Ram Heavy Duty exhaust system, reducing particulate matter is achieved through a self-cleaning Diesel Particulate Filter (DPF). The muffler is isolated from the emissions control system, therefore customers may remove the muffler without violating emissions compliance. The emissions system is designed for a government-certified 120,000 miles.
As durable as it is powerful, the Cummins 6.7-liter turbo-diesel engine has life-to-major overhaul intervals of 350,000 miles, providing more than a 100,000-mile advantage over the competition.
Quiet and Refined Driving Experience
In addition to improving emissions and durability, occupant comfort is central to the 2007 Dodge Ram Heavy Duty. The new 6.7-liter turbo-diesel engine incorporates several new features that contribute to a 50-percent quieter engine and a 3 Dba reduction in cabin sound levels, increasing the vehicle's overall refinement.
New engine mounts, a constrained-layered oil pan, intake silencer and engine-block shield create a quiet cabin environment inside the 2007 Dodge Ram Heavy Duty. In addition, an over-running alternator pulley eliminates sounds generated from the diesel engine shut down process, and machined crankshaft counter weights significantly contribute to quiet acceleration.
First-ever Optional Exhaust Brake
For the first time in a Dodge Ram Heavy Duty truck, an integrated exhaust brake is available direct from the factory. Utilizing the 6.7-liter Cummins turbo-diesel engine's new turbocharger, the exhaust brake significantly improves control when towing heavy applications, such as pulling RV fifth wheels and horse trailers, providing added control and brake savings by transforming horsepower into braking power.
"Towing and hauling capability is critical for our customers, as more than 90 percent of Dodge Ram Heavy Duty customers tow with their truck," said Kunselman.
Benefits of the exhaust brake include:
* Increased vehicle control to provide the owner additional peace of mind
when towing
* Enhanced safety by reducing overheating and fading of brakes on
downhill grades
* Lower cost of ownership, extending brake life by as much as three times
* Capability for faster cold-weather cab warming
The 2007 Dodge Ram Heavy Duty's 6.7-liter Cummins turbo-diesel engine's VGT is capable of creating the maximum exhaust restriction through a wide range of operating speeds, improving braking performance at low and high engine speeds. Testing has shown more than a 30 percent improvement in retarding torque at 2000 rpm compared with traditional brake exhaust methods.
Six-speed Automatic Transmission with Electronic Range Select (ERS)
Mated to the 6.7-liter Cummins turbo-diesel engine is a new six-speed 68RFE automatic transmission, which delivers optimum fuel economy and performance. A new Electronic Range Select (ERS) system is integrated with the transmission, enabling customers to select desired gears that match driving conditions.
The new six-speed automatic transmission features a best-in-class gear ratio spread of 5.16:1, allowing for superior launch capability. The sixth gear, also known as the second overdrive gear, provides an extremely low rpm at highway speeds, improving Dodge Ram Heavy Duty's fuel economy and passenger comfort. In addition, an added compounder and two clutches provide optimal shift quality, improved quietness and durability.
The transmission's new ERS system complements the 2007 Dodge Ram Heavy Duty's tow/haul mode, allowing for driver-actuated gear selection with a shifter-mounted switch. ERS provides greater control in unique driving conditions, such as towing heavy loads on severe inclines. The system includes electronic safeguards to prevent shifting that could cause engine damage.
Towing/Hauling
In addition to more horsepower and torque, Dodge Ram Heavy Duty boasts towing capability of 16,400 lbs., a payload of 5,020 lbs. and Gross Combined Weight Rating (GCWR) and Gross Vehicle Weight Rating (GVWR) of 23,000 lbs. and 12,200 lbs., respectively.
The 2007 Dodge Ram Heavy Duty provides a combination of standard and optional features that make towing easier, such as a Class IV hitch receiver with a seven-circuit wiring harness, 750-amp battery, heavy-duty engine cooling and an auxiliary transmission oil cooler.
Distinctive trailer-tow mirrors featured on Dodge Ram Heavy Duty trucks offer a large rear-viewing area that may be customized to drivers' needs and preferences. Mirrors provide two views on both sides: close-up and wide-out. In addition, mirrors flip up 90 degrees for viewing beyond wide trailers.
Chrysler Group Diesel-Powered Models
In the United States, current diesel-powered models include the Dodge Ram Heavy Duty, Dodge Sprinter and the new 3.0-liter V6 diesel Jeep Grand Cherokee, which hits the market in early 2007. In 1988, the Chrysler Group made a significant impact with the introduction of the Cummins 5.9-liter I-6 in heavy duty applications. Customer recognition is still exceptional and will continue with the new Cummins 6.7-liter turbo diesel.
In Europe, diesel-powered models account for more than half of Chrysler Group sales. The Chrysler 300C, Chrysler PT Cruiser and Dodge Caravan models continue to be popular.
Advanced diesel technology is part of the Chrysler Group's advanced propulsion technology umbrella, which also includes efficient gasoline engines, hybrids, flex-fuel vehicles and biodiesel capability.
Dodge Brand
With a U.S. market share of 7 percent, Dodge is the Chrysler Group's best- selling brand and the fifth largest nameplate in the U.S. automotive market. In 2005, Dodge sold more than 1.4 million vehicles in the global market. Dodge continues to lead the minivan market with a 19 percent market share in the U.S. In the highly competitive truck market, Dodge has a 16 percent market share. This year, Dodge enters key European volume segments.
Cummins
Cummins Inc., a global power leader, is a corporation of complementary business units that design, manufacture, distribute and service engines and related technologies, including fuel systems, controls, air handling, filtration, emission solutions, and electrical power generation systems. Headquartered in Columbus, Indiana, Cummins serves customers in more than 160 countries through its network of 550 company-owned and independent distributor facilities and more than 5,000 dealer locations. Cummins produces the diesel for the Dodge Ram 2500 and 3500 series.
2007 Dodge Ram Heavy Duty Cummins 6.7-liter Turbo-diesel Engine Details
Engine
6.7L 107mm bore x 124mm stroke
High swirl (2.4 DCS) combustion system
17.2:1 Compression ratio
Machined crankshaft counter weights
Viscous vibration damper
Air Handling
VGT - sliding nozzle (16 vane to eliminate turbine blade pass whistle)
Cooled EGR with cold-side EGR valve
Air inlet throttle
EGR cooler bypass
CCV with coalescing filter
Oil system
Tested with low ash oil API CJ4 (PC10)
Drain interval - 7500 miles
Total capacity - 13 qts on initial fill
Sump capacity - 9 qts low, 11 qts high
Typical oil change capacity - 12 qts
Dump to sump to provide oil pressure quicker
Constrained layer oil pan to reduce transmitted noise
Fuel system
Bosch 3rd generation common rail system
7 micron spin on filter
Tested with ultra low sulfur fuel - 15 ppm
Approved for bio-diesel fuel
Cooling system
Molded composite impeller for improved coolant flow
Electronics
CM2100 ECM
Double the CPU processing speed (40 to 80 MHz)
40% increase in memory
NVH
Over running alternator pulley (eliminate shut down squeal)
Intake silencer
Combustion system (multi injection events)
Block shields
Pulleys modified to reduce 'speaker' effect
Stuffer between transmission adapter and pan
Specifications
ENGINE: 6.7-LITER HIGH OUTPUT CUMMINS TURBO DIESEL I-6
Availability ---- Opt. - 2500, 3500; available Jan. 1, 2007
Type and Description ---- Six-cylinder, inline, liquid-cooled,
turbocharged, intercooled
Displacement ---- 408 cu. in. (6690 cu. cm)
Bore x Stroke ---- 4.21 x 4.88 (107 x 124)
Valve System ---- OHV, 24 valves, solid lifters
Fuel Injection ---- Electronic high-pressure common rail
Construction ---- Cast-iron block and head
Compression Ratio ---- 17.3:1
Power (SAE net) ---- 350 bhp (261 kW) @ 3,000 rpm
Torque (SAE net) ---- 650 lb.-ft. (881 N*m) @ 1,500 rpm w/6-spd.
automatic;
610 lb.-ft. (827 N*m) @1,400 rpm w/6-spd. manual
Maximum High-idle Engine Speed ---- 3,500 rpm
Fuel Requirement ---- Ultra Low Sulfur Diesel
Oil Capacity ---- 12 qt. (11.3L) with filter
Coolant Capacity ---- 29.5 qt. (28.0L)
Emission Controls ---- Exhaust after-treatment systems and internal engine
features
TRANSMISSION: 68RFE ORION-AUTOMATIC, SIX-SPEED
Availability ---- Opt. with 6.7L turbo diesel engine; available Jan. 1,
2007
Description ---- Three planetary gear sets, one overrunning clutch, full
electronic control, electronically controlled converter
clutch
Gear Ratios
1st ---- 3.231
2nd ---- 1.837
3rd ---- 1.410
4th ---- 1.0
5th ---- 0.816
6th ---- 0.625
Reverse ---- 4.444
Overall Top Gear Ratio ---- 2.33 with 3.73 axle ratio; 2.56 with 4.10 axle
ratio
Old Nov 1, 2006 | 12:37 PM
Drew's Avatar
Drew
Default RE: All about the Powerful 6.7-liter Cummins
already got most of this up top in the 6.7L thread I started.
Old Nov 1, 2006 | 01:05 PM
htgriffith's Avatar
htgriffith
Well Drew, I thought this had more detail, I thought it would help some members out, I did not put it up top due to the fact that it is fresh info and most have read the top post and felt it would be over looked. Just trying to help the members that have been asking for new info about this. If you think you should move it up than do so. Thanks
Old Nov 1, 2006 | 01:52 PM
Drew's Avatar
Drew
tell you what, I'll copy this and post it into the thread with updated specs
Old Nov 1, 2006 | 04:36 PM
TheWizard's Avatar
TheWizard
am i reading this wrong or is it putting Exhaust gas back into the Air intake? isnt that a bad idea? or is it normal practice? what i know about diesels could be written on a pen head with a Ram. thanks
Old Nov 1, 2006 | 04:57 PM
Drew's Avatar
Drew
gassers have been doing this same thing to reduce NOX emissions. basicaly the cooler you can make the fire the lower the NOX emissions, however doing so reduces power since you have to back the timeing down. the more timeing you give a diesel the more efficient it will be, however the NOX emissions are very high and some tree humper in california thinks this is a bad thing[:@]
Old Nov 1, 2006 | 11:55 PM
NickBeek's Avatar
NickBeek
ORIGINAL: TheWizard
You're darn tootin it's a bad idea. That cooled egr and throttle plate and vgt is how the 6.0L Ford is set up since '03. It has been a nightmare for them, and it is going to be a nightmare for Dodge soon. You take some very hot exhaust gas and divert it into a chamber with engine coolant running through a cooler. This cools it and then there is an egr valve that is controlled by the ecm to let some of that back into the intake. When the hot exhaust hits that cooler it has a high failure rate, which lets exhaust gas pressurise the coolant system and bam your puking coolant out of the tank, or worse the coolant leaks in to the exhaust stream and get cooked onto everything and flows out the tail pipe, probably killing your very expensive particulate filter. Now assuming that doesn't happen, (but it does often on the fords) then your egr valve cakes up with soot and stops operating properly every 10K-40K miles, which gets you a CEL and a trip to the dealer, or it starts bucking and farting when under load. Next fun thing is all that cooler exhaust gums up your high dollar VGT turbo which in turn underboosts and cuases smoke and poor performance, or it sticks in the other position and over boosts and you start blowing head gaskets, which again can manifest itself in coolant all over the place and some quality time with your dealer. This is why I now own a 2006 Dodge that does not have all that fancy headache stuff attached. Hopefully this truck will last long enough that they will find solutions to all these problems. Right now it seems as though it will, I have 11000 trouble free miles so far and my fuel economy keeps climbing and the smile is still on my face. If I want 350 hp and 650 tq I'll just add a CAI and delete my muffler and not worry about all the BS that comes with the new engine. Good luck to those that buy it, but not me.
Old Nov 2, 2006 | 06:29 AM
htgriffith's Avatar
htgriffith
Thanks Drew, Sounds good, Hope this helps someone out.
ORIGINAL: Drew
Old Nov 2, 2006 | 10:33 PM
speakle's Avatar
speakle
I really dont care about the engine, I would love to have a 6 sp a/t in my truck though.
Old Nov 4, 2006 | 10:35 AM
htgriffith's Avatar
htgriffith
ORIGINAL: speakle
Ya, Me to, Does some one know if it will bolt up? Man can you say MPG. HaHa
