Help Check Engine Light On
Old Nov 2, 2006 | 08:09 PM
DBLR's Avatar
DBLR
Default RE: Help Check Engine Light On
I guess I'm luck as after having it plugged in today for about 1.5 hr's, once started and I got ready to go I thought someone had turned up the fuel pump as it had a lot more get up and go power! I just wish the power stayed full time as each time it is off the extra power will may or may not be there the next time I start it [X(] Maybe I should plug it in more often if that is all it takes to get more HP, TQ out of it!
Old Nov 3, 2006 | 01:47 AM
spfd308's Avatar
spfd308
thanks for the help guys. i took it to the local parts store and they were able to clear the code. also i found it is the battery temp sensor. didn't figure i needed to be too worried but with the taking off on the trip tomorrow i knew i wouldn't be able to stare at the check engine light the whole time.
