Help Check Engine Light On
Old Nov 1, 2006 | 11:33 PM
spfd308's Avatar
spfd308
Default Help Check Engine Light On
So here's the scoop, plugged in the truck last night becuase it dipped down below the freezing. This morning I started it up and then unplugged the truck. The check engine was on when i got back into the truck. tonight i unplugged the quad box and disconnected the battery for 5 minutes then tried again. Still got the check engine light on even with the quad box unplugged. all is running fine with the rig but i need to get this fixed before friday since i'm taking off on a long weekend and will be doing about 2000 miles. any help is greatly appeciated.
Old Nov 1, 2006 | 11:42 PM
DieselDemon's Avatar
DieselDemon
Default RE: Help Check Engine Light On
Dealer.............. I have to believe it's under warranty still?
Old Nov 1, 2006 | 11:50 PM
spfd308's Avatar
spfd308
it is but i was hoping there was some way to get rid of the check engine light without having to pull my box and go to them.
Old Nov 2, 2006 | 12:15 AM
NickBeek's Avatar
NickBeek
Check for codes, look up code here. I'll bet it is the one for battery temp sensor. If so go to auto parts store they can clear codes. There is no fix that I have read about for this issue yet, but it is no biggy. If you do a search you will probably find this discussed a time or two.
Old Nov 2, 2006 | 12:18 AM
spfd308's Avatar
spfd308
Thanks nickbeek, i'll check into that in the morning and if it doesn't work, i guess i'll pull the box and make a run to the dealer.
Old Nov 2, 2006 | 02:12 AM
gtxpooch's Avatar
gtxpooch
I had the same problem with the block heater when I plugged it in. The dealer reflashed the computer and the problem went away. Pull your"box" before you take it in though.
Old Nov 2, 2006 | 02:22 AM
steve05ram360's Avatar
steve05ram360
do the key on-off method to get the code out, then go from there. if it is the batt temp sensor then go to the autoparts store and have them clear the code, then when you have time go to the dealer to get it squared away.
Old Nov 2, 2006 | 04:16 AM
Dodge This's Avatar
Dodge This
Had close to the same thing happen to my truck not too long ago. It was the batt temp. senor. Autozone could not clear the code so I had to take it to the dealer. No problems since. Good luck. REMEMBER to remove any aftermarket items so they dont void your warrenty.
Old Nov 2, 2006 | 10:48 AM
Drew's Avatar
Drew
also after 5 or so full starts the code will generaly clear itself out.
Old Nov 2, 2006 | 02:22 PM
Dodge This's Avatar
Dodge This
I tryed the five start thing with my truck did not work.
