isb 24valve High Idle???
Old Nov 20, 2006 | 07:05 PM
jakebrake's Avatar
jakebrake
Default isb 24valve High Idle???
Does the 98.5 to 02 have the high idle feature? Or is that only availible on the hpcr engines.
Old Nov 20, 2006 | 07:11 PM
Mayfair's Avatar
Mayfair
Default RE: isb 24valve High Idle???
What exactly IS the high idle feature?
Old Nov 20, 2006 | 07:14 PM
jakebrake's Avatar
jakebrake
Kicks the rpm up to around 1000 insted of 600 for faster warm up in the mornings and for running pto's. If the ecm doesn't have the option, I think I have come up with a way to do it.
Old Nov 20, 2006 | 07:26 PM
Mayfair's Avatar
Mayfair
I just hold my foot on the pedal for about a minute or so and then take off.
Old Nov 20, 2006 | 07:27 PM
Mayfair's Avatar
Mayfair
Does it drop the idle back down once the truck is all warmed up? THAT would be cool !!
Old Nov 20, 2006 | 07:31 PM
jakebrake's Avatar
jakebrake
I don't know about the new engines. I know the older 444's would idle up and down bassed on temp. I'm thinking what I will do is install a resistor to match what ever rpm I want with a switch so when I flip the switch on it idles up and when I flip the switch off it idles back down.
Old Nov 20, 2006 | 07:37 PM
Mayfair's Avatar
Mayfair
LOL ... pretty soon the inside of your truck is going to look like this ...
Old Nov 20, 2006 | 07:38 PM
blownsoot's Avatar
blownsoot
they idle up to 1000 rpm until the engine warms up or you take it out of park then it drops down to normal it seems like 20 degree air temp is where it kicks in
Old Nov 20, 2006 | 07:42 PM
jakebrake's Avatar
jakebrake
A man can dream
Old Nov 21, 2006 | 12:00 AM
GBWELDING's Avatar
GBWELDING
My 02 has the high idle feature and it will idle back down when warm but it,s not like the newer version that is controlled by the cruise control, still want a exaust brake to provide aload on the engine to speed the warmup and reduce cylinder wash.[8D]
