AFE CAI >>>.
Old Nov 24, 2006 | 02:07 AM
triton's Avatar
triton
Default AFE CAI >>>.
for those who have the AFE stage II CAI.......
I'm not sure about the 06 but, my 07 has the mass air sensor just out side of the air box in the tube.
Does the AFE tube have a location to mount he MAPP ? If not, what do you do with it... drill and tap ?
Old Nov 24, 2006 | 02:51 AM
SpLaT's Avatar
SpLaT
Default RE: AFE CAI >>>.
Yup... AFE has mount for MAPP on the tube, comes with soft gasket as well.
Old Nov 24, 2006 | 03:46 AM
steve05ram360's Avatar
steve05ram360
I could be wrong but I believe what's on mine is an air temp sensor. a mass air sensor would sample the entire intake tube air flow and would be round with a wire center of some sort. do you have a pic?
Old Nov 24, 2006 | 11:31 AM
triton's Avatar
triton
ORIGINAL: steve05ram360
I assume what's on my tube is a mass air sensor.... I could be wrong. In looking at pictures of the AFE
I couldn't really tell if it came set up to accept the stock sensor.
I imgine if it didn't one could be drilled and tapped in but, apparently it's very important to have it in the correct
location to avoid trouble codes.
here's a pic of the sensor mounted in a tube......
Old Nov 24, 2006 | 11:32 AM
triton's Avatar
triton
ORIGINAL: SpLaT
Thanks Splat. I thought it would have had it but, just wasn't sure.....
Old Nov 24, 2006 | 11:34 AM
triton's Avatar
triton
ORIGINAL: triton
I imagine if it didn't, one could be drilled and tapped in but, apparently it's very important to have it in the correct
Old Nov 24, 2006 | 11:42 AM
steve05ram360
Just looked in the FSM and it is an air temp sensor & a pressure sensor combo. (page 5972)
Old Nov 25, 2006 | 01:08 AM
triton's Avatar
triton
Thanks Steve. Sounds like another wasted bit of wiring [8D]
