Got my areo turbine today, where do I install?
Old Nov 28, 2006 | 06:32 PM
GOD RAM IT's Avatar
GOD RAM IT
Default RE: Got my areo turbine today, where do I install?
I just looked at my AERO.
I installed it backwards. What a Tard I am.
But the guy that had it before me installed it the same way.
damn it!
Old Nov 28, 2006 | 06:41 PM
Mayfair's Avatar
Mayfair
ORIGINAL: GOD RAM IT
damn it!
Switch it dude !!
I don't know if they're all the same, but assuming that they are, the rings go towards the back. Check out your instruction sheet.
Don't be so hard on yourself. Apparently it happens all the time. It happened to ME !! If you look at my Aero, you'll see a short pipe before and after it. That's because the guy's installed it backwards. Because they had to swicth it around, the welds had to be cut out, thus making the pipe shorter. If it wasn't for the guy's at Aero telling my exhuat guy's to switch it around, I would have been screwed. The muffler guy wanted to charge me again for turning it around. Things were getting ugly FAST, but cooler heads prevailed and things got fixed before I had to popa cap in his a$$.
[IMG]local://upfiles/42139/4204C515D8184ABD8AE1D67794D6FA62.jpg[/IMG]
Old Nov 28, 2006 | 06:44 PM
Mayfair's Avatar
Mayfair
Thinking more .... that's probably why you didn't notice a difference when you took your silencer ring out too.
Switch it around.
The Aero guy told me that it'll do more harm than good if I would have left it that way ( backwards ).
Old Nov 28, 2006 | 06:56 PM
GOD RAM IT's Avatar
GOD RAM IT
well I guess that answers that. Hopefully I can get the pipe off without cutting it off. Im going to stop by NAPA and see what kind of clamps they have. They said they had TORCTIE ones like the two that i had gotten. so we'll see
Old Nov 28, 2006 | 07:00 PM
Mayfair's Avatar
Mayfair
Did you weld it or clamp it in?
Old Nov 28, 2006 | 07:03 PM
GOD RAM IT's Avatar
GOD RAM IT
clamp it. But I only had 2 torctite clamps and I needed 1 more clamp so I reused the stock c-clamp style which usually bends the pipe and makes it impossible th remove the pipes without cutting them.
Old Nov 28, 2006 | 07:25 PM
steve05ram360's Avatar
steve05ram360
ORIGINAL: steve05ram360
loose the cat and replace it with the aero. keep the cat in the garage in case you ever need it. I also recommend going to a straight true muffler to replace the stocker. the 2 mufflers on there have proven to be an awesome setup. I Cant comment on the aero by itself though... someone else will have to chime in on that.
Steve you are cornfusing
replace the cat with the AERO and leave the muffler? Dont you mean leave the cat and replace the muffler with the AERO then eventually get a straight through cat like a Magnflow?
no, what I mean is remove the cat, install the aero where the cat was and either straight pipe the stock muffler or put a 30" magnaflow in there. the stock muffler should be yanked (should have made it clearer).
Old Nov 28, 2006 | 07:27 PM
Mayfair's Avatar
Mayfair
Steve, where would you put the cat if you DID hafta leave it in? I think that's the jist of the question?
GOD RAM IT's Avatar
GOD RAM IT
ah I got you
Old Nov 28, 2006 | 07:29 PM
dtb86001's Avatar
dtb86001
steve
did you run your truck with the stock muffler for any amount of time after you installed the aero and could you compare your MPG against running with the 30" magnaflow.
