CB Suggestions
RE: CB Suggestions
Cobra 29 NWST, it's a fairly large unit, so I mounted it on the Cup holder "swing down". I don't use the cup holder anyway because I need to lean up and to the right to grab my Pepsi One. I always run with the center seat-back in the down position and use it as a storage bin and table. I mounted a cup holder with "Velcro" to the top right side and use that instead. I just need to be carefull not to open the lid with a full can in the holder. I use a Wilson 1000 base load antenna right over dome light, the antenna wire comes in at the dome light position, and is totally hidden behind the trim.
Ralph
Ralph
RE: CB Suggestions
ORIGINAL: RobertDunn
as for Gain, essentially it increases or decreses the range that your CB will pick up/transmit. like a "Power" setting. I would recommend this in leu of a Squelch or other dohicky, on the radio.
Your saying that I should be using the RF for fin tuning and NOT the squelch? What do i use the squlech for then?
RE: CB Suggestions
ORIGINAL: Mayfair
Yeah, that's waht it said in the book. RF Gain was for increasing / decreasing the range. Iwas like, "why the heck would you DECREASE your range" so I turned it all the way up. I too have a squelch ****, and I was using that to kinda fine tune.
RE: CB Suggestions
ORIGINAL: chukar
Of those who have CB's or those who want one, what are your recommendations for brand/model and such? Also, I've got an 06 with manual trans, doesn't look like too many places to mount one that will be out of the way enough to shift, but convenient enough to access the unit when desired. I would also like to install a brake controller and think that should be more accessible than the CB seeing as how it is a little more important to get to in a pinch.
Thanks
Thanks
Mayfair, go half way on the RF Gain, then use squelch to trim out the noise. If you get in a really noisey area and the squelch won't cut it then turn down the gain.
RE: CB Suggestions
I thought about putting a CB there, in front of the 4X shifter, but then again I don't know where the brake controller would go. If I put it to the left of the 4X shifter there won't be any leg room.
Guess I better get a CB first before I worry about where I am going to put it.
