oil bypass install this weekend...
Old 12-18-2006 | 02:40 PM
Mayfair's Avatar
Mayfair
Default RE: oil bypass install this weekend...
I really don't think it's as bad as you think it is Steve. I think you'll be fine.
  #22
Old 12-18-2006 | 02:42 PM
steve05ram360's Avatar
steve05ram360
it comes down even with the tranny pan & lower control arm...maybe it would be prudent to install a valve on the inlet side to shut it off if it gets hammered and leaks...
  #23
Old 12-24-2006 | 03:36 PM
steve05ram360
Well Kids, the install is just about done... filter is mounted, hoses are run, just need to cut down 1 last hose and add the fitting, then hook it up and it's good to go.
I would have had it done last night but the Sharks were on @ 7... priorities you know
Quick Reply: oil bypass install this weekend...
