what is a miller tool??
Old Dec 16, 2006 | 04:33 AM
i11m10c2's Avatar
i11m10c2
Default what is a miller tool??
What is a miller connector tool .The jake brake install instructions say i need it and dont have a clue what it is??
Old Dec 17, 2006 | 01:45 AM
i11m10c2's Avatar
i11m10c2
Default RE: what is a miller tool??
NOTHING!! DREW WHERE ARE YOU?
Old Dec 17, 2006 | 02:11 AM
Batphreak's Avatar
Batphreak
Found this on the web:
http://www.jakebrake.com/support/doc...0E2_Screen.pdf
Is this the same instructions you are looking at? Since it says a small flat screwdriver can subsitute I'm guessing the miller connector tool is for removing pins in a connector. Usually special tools make it easy, but all the really has to be done is push down the right tang inside the connector and the pin or socket can be pulled out.
Old Dec 17, 2006 | 03:47 PM
steve05ram360's Avatar
steve05ram360
sounds like a small flat blade screwdriver will work... read part of the instructions and under tools needed, in quotes it indicates a flat blade would work...
Old Dec 18, 2006 | 02:12 AM
squirtbottle09's Avatar
squirtbottle09
By the posts above i am guessing that it can be replaced by a small flat bladed screwdriver
Old Dec 18, 2006 | 03:38 AM
i11m10c2's Avatar
i11m10c2
okthnks for the responses. i will be doing instal on tuesday ,wish me luck
Old Dec 18, 2006 | 02:39 PM
steve05ram360
OK, how about pics and a writeup?
Old Dec 18, 2006 | 02:48 PM
jakebrake's Avatar
jakebrake
You'll probably have to grind the srewdriver down to make it real small if it is the tool I'm thinking of. Can't find a pic of it on the internet[:@]
Old Dec 19, 2006 | 02:32 AM
i11m10c2's Avatar
i11m10c2
Iwould but the jakobs website has a pdf with a-z instructions with step by step pics ,Its basicly the instal guide in pdf form ,and my camera is on its way back from europe in a box,Hopefully it will be here soon so i can take pics,i will post some pics of it when i get the camera.
