Warning - K&N Oil Filter - Metal Shavings
Old Dec 16, 2006 | 07:48 PM
rneal's Avatar
rneal
Default Warning - K&N Oil Filter - Metal Shavings
Just wanted to make sure everyone was aware of an issue that I encountered with the K&Noil filters (Part# HP-4003). I recently purchased one of these fromthe corner auto parts store here in TN to put on my 97 Dodge CTD (Sweet Machine, I might add!) As I went to rub a thin coat of oil on the rubber seal I noticed some metal shavings on the threads of the filter. On closer inspection, I found that there was aconsiderable amount of shavingswhere the ports and threads had been machined into the filter. I took the filter back to a different store to swap out and found the same problem on all of their K&N filters, too.
I ended up buying a generic oil filter for this oil change and have emailed this to K&N. It seems that they may need to relook at how they are cleaning the filter housings before they ship them off from the factory. K&N has put out some great products, and I will continue to use them on all my Bikes, Cars, and Trucks. However, I can't believe that this slipped by theirQA folks.
Thanks,
RNeal
Old Dec 16, 2006 | 11:41 PM
PRam's Avatar
PRam
Default RE: Warning - K&N Oil Filter - Metal Shavings
That's good info, I have never used the k&n filter. I always get the Fleetguard filter (a Cummins product) that way if there is any issues I know I'm covered under warranty. I get mine locally in Knoxville but Geno's Garage online has them cheaper.
Old Dec 18, 2006 | 03:02 AM
Mayfair's Avatar
Mayfair
Welcome aboard rneal and THANKS for a VERY good first post !!!
