Loads
Old Dec 24, 2006 | 04:22 PM
Greywolf66's Avatar
Greywolf66
Default Loads
I just purchased a Eaglecap camper for my Dodge 2001 3500 4x4 Quad 6 speed diesel. The dry weight of the camper is 3198. Will I have a problem with this weight on this truck, and if so what can I do.
Thanks Tom
Old Dec 24, 2006 | 05:34 PM
DBLR's Avatar
DBLR
Default RE: Loads
You did not say if you had a long or short box. Also do you have duels or SRW on your truck As this info will help others to give you this information.?
Old Dec 24, 2006 | 06:13 PM
Greywolf66's Avatar
Greywolf66
Default RE: Loads
I have the long bed and the duels
Old Dec 24, 2006 | 07:59 PM
DBLR's Avatar
DBLR
Default RE: Loads
I have been told that their should be a tag inside of the glove box with this info on the max bed weight for your truck. In my 06 2500 Short box QC SWR I can carry 2150 lsb. so you may be safe at 3198 lbs. Being it's Christmas time if you don't get an answer by say Tuesday afternoon then give this post a bump to the top so the others who were away can read this post and offer better help.
Old Dec 25, 2006 | 01:18 AM
dhvaughan's Avatar
dhvaughan
Default RE: Loads
i think your truck will handle it just fine. it the front or the rear squats more than you like you might want to check out these helper springs. i've heard lots of good things about them.
http://www.timbren.com/timbren-appli...dodge-jeep.htm
Old Dec 25, 2006 | 02:22 AM
NickBeek's Avatar
NickBeek
Default RE: Loads
You may also want to visit the Dodge web site for towing and hauling capacities. I know they were there for my truck, not sure how far back they go. I would confirm an answer before trying it out. Good luck.
Old Dec 25, 2006 | 02:46 PM
cj5nutz's Avatar
cj5nutz
Junior Member
Default RE: Loads
I have the Timbren overloads that replace the factory bump stops. Only thing to worry about after that is popping your tires : )
Old Dec 25, 2006 | 03:09 PM
KenZ's Avatar
KenZ
Default RE: Loads
Shouldn't have many problems. Definantly check out the official weight limits, either from DCX or there are others on the net. Try maybe the Goodsam website or the Trailer Life website. My truck is a '05 2 wheel drive dually with the Diesel 6-spd and I pull a fifth wheel with about 3200 lbs of hitch weight. Never had a problem. I haven't looked up the limits on this truck, but my last two duallys ( one chevy and one powerstroke), and they where both around 5400lbs payload cap. Might need to stiffen up the suspension or add a heavy duty sway bar just because the weight of the camper is a little on the top heavy side.
Happy camping
KenZ
michigan
Old Dec 27, 2006 | 01:25 AM
CowboyBob's Avatar
CowboyBob
Default RE: Loads
Definately check the weight limit on the tires. I think you'll be OK with some helper springs. They certainly can't hurt and don't cost much.
Old Jan 1, 2007 | 03:22 AM
Greywolf66's Avatar
Greywolf66
Default RE: Loads
Thanks for the info, I was thinking shocks and helper springs. I will have to check what my tire limits are
Tom
