Front Wheel Bearing Greasing
Old Jan 2, 2007 | 12:16 AM
lesimon's Avatar
lesimon
Default Front Wheel Bearing Greasing
Today I serviced the passengers front wheel bearings. I am posting this message to let everyone know that I am glad that I pulled the bearing apart for servicing. After removing the hub assembly and separating the bearing I found that the bearing had been over heated to the point of discolouring the hub itself, the grease was baked. The bearing rollers where also discoloured. I am expecting this bearing to fail before the other side but I might have bought myself a year or two more out of this damaged bearing. Hopefully this will help someone else out there.
Old Jan 2, 2007 | 03:54 AM
gtxpooch's Avatar
gtxpooch
Default RE: Front Wheel Bearing Greasing
What year of vehicle? 2500/3500? 4x4 I presume?
Old Jan 2, 2007 | 03:12 PM
DBLR's Avatar
DBLR
More infro of what year your truck is and if it's a 4x4 would sure help the rest of us out.
Old Jan 2, 2007 | 11:42 PM
lesimon's Avatar
lesimon
Sorry guys 2005 Dodge Ram 3500 Laramie, 4x4, automatic.
Old Jan 3, 2007 | 01:18 AM
Drew's Avatar
Drew
thanks for the heads up. . .Ive got to replace the muffler bearings in my yoda, then I might tackle this.
Old Jan 3, 2007 | 04:04 AM
rshackleford's Avatar
rshackleford
Do the 2500's not have sealed wheel bearings?
Old Jan 3, 2007 | 05:22 AM
dodgerules86's Avatar
dodgerules86
ORIGINAL: Drew
Make sure you get some blinker fluid while your at the auto parts store.
Old Jan 3, 2007 | 12:29 PM
dieselram's Avatar
dieselram
What are some signs that the wheel bearings might need to be disassembled and greased?
Old Jan 4, 2007 | 01:49 AM
lesimon's Avatar
lesimon
These where sealed bearings, I had read about how difficult it was to get them apart after a few years so I decided to repack them and apply never sieze compound to make dissasembly a whole lot easier later on. I have also found other equipment/trailers/recreational vehicles from the factory that have had little or no grease in the bearings. I had no indication that anything was wrong with the wheel bearing until I had dissasembled them. Note that the drivers side was fine, the passangers side I had to jump on the flex bar with both feet to break the nut loose, I suspect that it was over-torqued, therefor overheating the bearing.
