water leaking???
Old Jan 6, 2007 | 08:10 PM
crazykidjj87's Avatar
crazykidjj87
Default water leaking???
so i came home today after work and i noticed water dripping from under my truck so i popped the hood to investigate. on the passangers side comming out of the fire wall there is a hard (possibly metal) pipe/tube. and a good amount of water was comming out of it. it wasnt like a garden hose or anything it was just a nice slow steady stream/drip and it was cold. i didnt have the a/c on at all and its january and it was 66 degrees out today here in CT. what on earth is this water? and where did it come from?
Old Jan 6, 2007 | 08:40 PM
RyEnFF31's Avatar
RyEnFF31
Default RE: water leaking???
I had a similar problem. I had a hose leaking under the turbo. It was easier to see from the passanger side wheel well. All I had to do was tighten a hose clamp and add some coolant. I hope that helps.
Ryan
Old Jan 6, 2007 | 09:12 PM
crazykidjj87
i dont thinkt i was coolant. it was clear cold water. and it was just an open pipe. like nothing on the end of it or anything
Old Jan 6, 2007 | 11:23 PM
RyEnFF31's Avatar
RyEnFF31
If you were running the defog on the heater it still causes the A/C compressor to run to dry out the air eliminating the fog on the windows. It was probably just condensate.
Old Jan 7, 2007 | 12:39 AM
NickBeek's Avatar
NickBeek
Fill out your signature so we know what options you have. If you have the climate control option it will cycle the A/C in just about every mode. Like was said already if you were running the defrost that cycles the A/C too.
Old Jan 7, 2007 | 12:09 PM
cumminalong's Avatar
cumminalong
Did you say it was just an open pipe?
Most likely just the drain for the condenser.
If it was humid out, you'll still get a lot of drainage with the defrost on.
Old Jan 7, 2007 | 04:16 PM
crazykidjj87
yes i had it in the defog mode so thats all it was then. i figguured it was condensation but i didnt have the **** on a/c so i didnt know what was goin on. thanks guys
Old Jan 16, 2007 | 04:22 PM
Cumminnotstrokin's Avatar
Cumminnotstrokin
On all of the newer vehicals the ac will run when the heater is on. They use the ac to dry the air first to help stop the windows from fogging your leak my be normal condinsation
Old Jan 16, 2007 | 08:41 PM
Mayfair's Avatar
Mayfair
I remember being scared to death the first time I saw all of that water as well. Looks like somone dumped a 5 gallon fish tank under there.
Old Jan 16, 2007 | 08:46 PM
crazykidjj87
ya i saw it and i was liike wtfffffffffff....i didnt know what it was...assumed it was water but wasnt sure....glad i know its nothing now
thanks guys
