305's on stock rims
Old Jan 11, 2007 | 05:07 AM
moconst's Avatar
moconst
Default 305's on stock rims
Just wondering if anyone runs 305 70 17 on there truck, I am thinking about getting a set but not sure how they look on stock rims. I personally like the stock rims and dont want to buy new ones if dont need too. Thanks
Old Jan 11, 2007 | 01:40 PM
steve05ram360's Avatar
steve05ram360
Default RE: 305's on stock rims
you should have no problem... that is a 34" tire... some guys run 305/75-17's and they rub just a slight amount... an inch shorter should give you plenty of room.
Old Jan 12, 2007 | 01:05 AM
moconst's Avatar
moconst
Thanks Steve, I m going to start looking this weekend. Maybe catch a good deal, who knows.
Old Jan 12, 2007 | 04:07 AM
teeminus's Avatar
teeminus
I am running 305/70/17 Goodyear MTR's on the stock rims on my '06 2500 Quad Cab 4x4. Makes the truck look great! Lookout for a 3-4 MPG decrease though...
Old Jan 12, 2007 | 01:47 PM
steve05ram360
search on craigslist for hummer tires... they have BFG's taken off for tire/rim upgrades on there.
Old Jan 12, 2007 | 07:13 PM
Helmut's Avatar
Helmut
Teeminus are you sure about the drop? Having larger tires affects the speedo and odometer. It shows a lesser distance while you actually go further. Time yourself on the highway between mile markers at 60 mph- if the speedo is on it will take 1 minute. If it takes less then that you are going faster than 60(distance traveled longer than a mile) although the speedo says 60. When I switched the tires on my Jeep (without changing the input gear on the t-case) from 215/75 to 31/10.50 my speedo droped about 5 mph and I was recording 90 miles on a 100 mile trip.
Old Jan 12, 2007 | 07:14 PM
GlenninTexas's Avatar
GlenninTexas
I run 305/70- -16s on stock rims. Certainly the max you want to do. Tire guys told be to run with just a little bit less air pressure because of the width of the tire to the wheel. I do get just a bit of rub.
Regards, Glenn
Old Jan 12, 2007 | 07:37 PM
Ram On's Avatar
Ram On
Here's a good calculator-http://www.1010tires.com/TireSizeCalculator.asp?action=submit
I was thinking of upgrading to 20" wheels with 33" tires. Are there any drawbacks to this? 2006 2500 megacab
Old Jan 12, 2007 | 11:47 PM
Welder597's Avatar
Welder597
I dropped 3 mpg going to 35-12.50-17 on my stock rims. Just a little rub at full turn. 2005 3500 4x4 Quad Cab
Old Jan 12, 2007 | 11:56 PM
cumminalong's Avatar
cumminalong
Might also wanna consider 295/75/17. Same height (actually slightly taller), but will fit the rim better. You're talking a 11.5" wide tire (295) compared to a 12.5" (305)
305 is a bit wide for the stock rims. Most of the manufacturers recommend at least an 8.5" wide rim for that width.
