Diagnostic Trouble Codes FULL List
Old Jul 29, 2017 | 09:23 PM
  #31
Winter In Vegas's Avatar
Winter In Vegas
Default Code in Magnum starts with a U ????!!!!!!
So I have ongoing issues with an instrument cluster and a couple new codes popped up when I was trying to get the part number off the cluster, U1403 & U1411. Any idea what these mean??
I need serious help with my 06Magnum RT AWD. Instrument Cluster and no check engine light illumination. Failing Smog and unable to register. Please help!
Renee Winter
Old Jul 29, 2017 | 10:42 PM
  #32
U1403-IMPLAUSIBLE FUEL LEVEL SIGNAL
The fuel level message that the PCM is receiving is implausible. The circuit is continuously monitored.
Possible Causes
CAN B OPEN OR SHORTED
CLUSTER MODULE
FRONT CONTROL MODULE
PCM
U1411-IMPLAUSIBLE FUEL VOLUME SIGNAL RECEIVED
The fuel volume message that the PCM is receiving is implausible. The circuit is continuously monitored.
Possible Causes
CLUSTER MODULE
PCM
You really should be posting in the Magnum section. Welcome to DF!
Old Aug 9, 2017 | 08:24 AM
  #33
rockytopman2's Avatar
rockytopman2
Default 2007 RAM 3500 5.9 Cummins
I get Code PO299 which is not shown on list. States Faulty Low Boost Sensor on my code reader. Does not usually light Check Engine Light. Question: Where is the Sensor located. Is it the Sensor located at top of air tube where it connects to Air Filter Box?
Old Mar 19, 2018 | 07:33 PM
  #34
drpfister's Avatar
drpfister
Default Engine Code
New to this site. I have an engine code Hr4368. Cannot find reference. Any ideas?
Old Mar 19, 2018 | 07:34 PM
  #35
Where did you get the code from?
Old Apr 8, 2018 | 07:49 PM
  #36
DodgyHodgy's Avatar
DodgyHodgy
Default Code Location
Hi guys.
Is there any possible way to retrieve diagnostic codes without a diagnostic machine? Im pretty new to this. I have a 2006 Dodge Caliber CRD, 2.0 Diesel. The Engine Management light sprang in the other day.
Any help is appreciated!
Thanks!
Old Feb 23, 2019 | 03:50 PM
  #37
floridaguy's Avatar
floridaguy
Default p0300 p0301
i changed wires plugs coil pack it still shows up
Old Feb 9, 2021 | 02:01 PM
  #38
Mikej2500's Avatar
Mikej2500
Default Can anyone help me identify the codes?
Just picked up this 2500 5.7 have a little trouble identifying codes I cannot figure out what b7/b8 is but the 64 and 81 are apparently driver door lock and remote radio switch..? Looking for any help thanks
C codes 64,41/81,00/
B codes b7,01/b8,01
Old Jul 27, 2023 | 07:49 PM
  #39
DTOOT's Avatar
DTOOT
I HAVE PO491 BUT YOUR CODE IS DIFFERENT FROM MINE YOU HAVE P0419
Secondary Air Injection System Relay “B†Circuit
Malfunction
Old Jul 28, 2023 | 07:49 AM
  #40
Malfunction
What are you driving?
