truck dies in cold weather
Old Feb 4, 2007 | 05:04 AM
htgriffith's Avatar
htgriffith
Default RE: truck dies in cold weather
The "click" as you probably know is the relay opening back up. Failing or badglow plugs can be indicated by a "hard start" condition, but a better indication is when one cylinder is "missing" when the engine is cold, but the engine runs smoothly when warmed up. Your glow plugs can be tested by you very easily if you wont to check it out. If you do not already know I will be happy to help you out.
Old Feb 4, 2007 | 05:14 AM
TexasRebel's Avatar
TexasRebel
ok, so how do i test my heater grid .
Old Feb 4, 2007 | 05:36 AM
htgriffith's Avatar
htgriffith
Is your lights dimming win your grid cycles? Or your volt meter drooping? We know your relay is opening and closing. We know have to find out if the solenoid is working.
Old Feb 4, 2007 | 05:51 AM
TexasRebel's Avatar
TexasRebel
yes it does have a power surge when its started,the lights and volt gauge cycles until it gets warm enough.
Old Feb 4, 2007 | 06:13 AM
htgriffith's Avatar
htgriffith
So the preheat and the post-heat cycles are working? The lights/volt meter keep dimming even after it starts? If it does not after the engine has been started the post-heat cycle is not working or is not working long enough. It should be on for 10 sec and off 15 sec +/- depending on air temperature . If this is the case it most likely it is the air temperature sensor. It seems your element, relay etc. is working due to the dimming of your lights.
Old Feb 4, 2007 | 06:21 AM
TexasRebel's Avatar
TexasRebel
Is it the intake air sensor or the feul heater sensor and how canI check them.
Old Feb 4, 2007 | 02:47 PM
Watermelon's Avatar
Watermelon
Cummins NO GLOW PLUGS
Old Feb 4, 2007 | 02:48 PM
DBLR's Avatar
DBLR
[] The CTD does not and never has had Glow Plugs [&:] The CTD has a Grid Heater
Thank You, We will now return you to your normal Channel!
Old Feb 4, 2007 | 02:50 PM
Watermelon's Avatar
Watermelon
The lights dim and the volt meter drops when the GRID HEATER is cycling.
Old Feb 4, 2007 | 09:16 PM
TexasRebel's Avatar
TexasRebel
Anyone else have a clue as to whats going with my truck?
Please chime in .
