Slow warm up and little heat
I just bought my first diesel Saturday and I have a few questions. New 06 Cummings and it takes at least twenty minutes of driving before the temp gauge comes off of 140 deg. Very little heat. I'm used to my Hemi that would heat up quick no matter how cold it was and the heater would run you out.Does anybody know what the normal operating temp should be and even though it's butt cold where I am shouldn't I be able to at least get warm air after driving for 25 minutes? Any help would be appreciated.
Thanks
John
Thanks
John
on
You will need to go buy a winter front that is the only way to help heat up a one half ton of cast iron engine with 7 gallons of anti freeze in it. I can related to what hapens to you as last night I had my winter front closed compleatly off and it was -15 below zero and I had it running for 3-4 minutes at 1100 RPM and then drove it about 4 miles home at speeds between 30 & 55 mph and it never saw above 160. With out a winter front at very cold temps it is very hard to heat your engine up with out a winter front so go buy on as soon as you can. You can find them on E-bay or at your local Dodge dealer for about $120.00
on
yea i have the block heater and a home made winter front a piece of cardboard..
and it still takes a good 20 minutes... i invested in a set of butt warmers... heated seats are a must in cold weather... if you go to heatedseatkits.com they are pretty good warm up asap. deff a must
Trending Topics
on
ORIGINAL: dixiedodge7369
One other thing is I use 5w40 synthetic oil so I don't have to worry about oil flow or start up problems in cold temps like I would if I had heavy 15w40 in it. I've talked to one person close by and his Cummins would not start as it still had 15w40 in it. He had to push it in to the garage to heat it up before it would turn over fast enought to start.
