Trany??
Old Feb 6, 2007 | 12:57 AM
dillyw's Avatar
dillyw
Default Trany??
Just went for a ride to store and everytime i stoped and gave it gas to go it didnt for about 2-3seconds everytime?? than kind of jump due to the rews being high , like it was chocking or something . sorry for spell. An the way back i tryed it at speed and the same thing , when i gave it gas it frooze than went , what is happening ?? any ideas?
Old Feb 6, 2007 | 01:45 AM
jakebrake's Avatar
jakebrake
Default RE: Trany??
Sounds like a torque converter. Any power mods???
Old Feb 6, 2007 | 02:39 AM
dillyw's Avatar
dillyw
Default RE: Trany??
No none , and an top of that it was just checked over by the dealership couse i bought it in adifferent city and wanted to make sure it was fine.
Old Feb 6, 2007 | 03:18 AM
beachmstr's Avatar
beachmstr
Default RE: Trany??
My gut says trany and that you need to get it checked by a trans shop. Good luck and wishin u the best.
Old Feb 6, 2007 | 10:15 AM
brandoncrone's Avatar
brandoncrone
Default RE: Trany??
When it feels like it won't go, try putting the shifter down to manual 1st. If it goes then you either have one of two things going on, the valve body is bad or the governor pressure solenoid is faulty. The solenoid is cheaper than the valve body
Old Feb 6, 2007 | 01:11 PM
dillyw's Avatar
dillyw
Default RE: Trany??
Thanks for input , went out this morning it was fine ,once it got warm it started again?
This sucks as i need to work tommorow, and also going out now will see what happens .I will call local tranny place , the dealrship told me Fri.
So no choice an the local shop.
Old Feb 6, 2007 | 01:37 PM
AMERICANRAM's Avatar
AMERICANRAM
Default RE: Trany??
I had that problem a while back in the winter season,it turned out to be that the diesel fuel was starting to freeze up,I just started adding anti gell to thefuel and the problem went away.So if you live in a cold state you might want to try that before spending your money on other fixes.
Good luck Mike
Old Feb 6, 2007 | 03:48 PM
dillyw's Avatar
dillyw
Default RE: Trany??
Thanx (Americanram) thats what my brother told me to try , hope it works.would be nice.
Old Feb 6, 2007 | 11:06 PM
dillyw's Avatar
dillyw
Default RE: Trany??
well i got some anti gel stuff and Drews brew mix and its all GOOD thank God , it was geling up for sure .
thanks for the help.
Old Feb 7, 2007 | 04:35 PM
MrSlug's Avatar
MrSlug
Default RE: Trany??
Wow. Aint it great when a problem can be solved with a 6 dollar bottle, vs a 1100-1500 dollar TC? Glad it was a minor issue.
