Cat Back Exhaust. Is it worth the money??
02-06-2007, 01:14 PM
on
98 - 12valve. Is it worth the money to go to a 4 inch exhaust??? What can I expect in the way of power? Economy? Performance? thank you
02-06-2007, 02:39 PM
on
RE: Cat Back Exhaust. Is it worth the money??
Cat back ??
I don't know if you're going to do yourself any favors by going from the cat back. If I were going to do it, I'd replace the entire exhaust system including the downpipe ( loose the cat ) and do the entire system in 4". Of course I'd use an Aero.
02-06-2007, 02:45 PM
on
I believe here in colorado we have to keep the converter. What kind of performance / mileage difference did you find when you did your conversion?
02-06-2007, 03:42 PM
on
I kept my stock 3.5" downpipe and used the same 3.5" Aero. I didn't have a cat, I had a resonator. The truck sounds awesome.
02-06-2007, 11:31 PM
on
Most lose MPG going to bigger pipes
02-07-2007, 05:37 PM
on
Why would you lose mpg by going to larger pipes? I would think you would get better MPG by having it run and breathing better?
02-07-2007, 07:30 PM
on
Mostly it is because the turbo does require some back pressure to perform correctly.
