check engine light
Old Feb 13, 2007 | 10:54 PM
06Dieselpower's Avatar
06Dieselpower
Default check engine light
[]dealer says battery temp, they reset, and 2 days later its on again
Old Feb 13, 2007 | 11:28 PM
triton's Avatar
triton
Default RE: check engine light
ORIGINAL: 06Dieselpower
have you checked the codes yourself ? I'm curious as to what the code is. I may be wrong but, I don't see how there could be a battery " temp " code. The batteries don't have a temp probe. I've seen battery voltage codes.
Old Feb 14, 2007 | 12:00 AM
06Dieselpower
Just bought the truck, only have it 3 weeks,and Don't know how to check codes, this is all new to me, looking foward to learning,I'm going to the dealer tomarrow and willlet you now the codes tomorrow night. (awsome truck man)
Old Feb 14, 2007 | 12:02 AM
triton's Avatar
triton
all you need to do is stick to key in and turn it on and off three times without starting the motor within I believe 10 seconds. Watch the odometer window and it will start to list any codes in your computer. Write it or them down and post back.
Someone should be able to give you an idea about what's going on.
Old Feb 14, 2007 | 12:04 AM
06Dieselpower
Ok, thank you for your help
Old Feb 14, 2007 | 02:41 AM
Mayfair's Avatar
Mayfair
I actually remember Drew mentioning that code before. I don't remember the entire gist of it, but that code does exist. Hopefully someone else here will remember it.
BTW: [sm=welcomesign.gif]
Old Feb 14, 2007 | 10:18 AM
DBLR's Avatar
DBLR
Also fill in your sig file so we all know what year truck, model and what trans you have. Several of us here have a list of what each code means so post it so one of us can tell you what it means.
Old Feb 14, 2007 | 11:10 AM
cumminalong's Avatar
cumminalong
Ahh yes, the infamous batt temp sensor....
Have you been plugging the truck in? If yes, here's your problem. If no, it may just be a bad sensor (this is a known issue).
1 - It's needs to be flashed and / or have that sensor replaced.
2 - The reason it comes on is the TIPCM sees a different of more than 2.6 degrees between your coolant temp, batt temp and air intake temp. This causes the CEL to come one. The flash is suppossed to address this.
3 - On mine, they replaced all three of those sensors, the entire wiring harness and the TIPCM (mine wouldn't hold the flash for more than a few days and would then revert back).
This has aparrently been an issue and DC is aware of it.
Old Feb 14, 2007 | 05:40 PM
06Dieselpower
W'ell never made the dealer today. they called to cancil,I'm going back friday,
Old Feb 14, 2007 | 10:57 PM
Dodge This's Avatar
Dodge This
I had the same code. Took to dealer first time the said nothing was wrong. Happened again a week or so later took back to the dealer flashed the ECM, and all has been good for several months.
