Taller tires=more or less mileage on the CTD?
Old 02-28-2007, 03:42 PM
zerodog's Avatar
zerodog
zerodog is offline
Default Taller tires=more or less mileage on the CTD?
I think I am running 265s now. Would taller tires help mileage or kick my ***? I seem to be getting 16 for all around mileage now.
Old 02-28-2007, 03:49 PM
ds06's Avatar
ds06
ds06 is offline
Default RE: Taller tires=more or less mileage on the CTD?
being a jeep guy (90 cherokee, yes i'm gonna get a cummins as soon as i get the money...poor college kid) this question is asked all the time, and yea, it'll affect your milage, AND ur speedometer is going to be off (i go by 10%). I went from about 29's to 32's. Long story short, yea, i'm pretty sure it'll lower your milage.
Old 02-28-2007, 04:42 PM
Drew's Avatar
Drew
Drew is offline
larger rotating mass to move(and stop), also it will effect the overall gearing of the truck. . .it will lower the mileage, but not by much depending on how big you go.
Old 02-28-2007, 07:25 PM
CutterW's Avatar
CutterW
CutterW is offline
I went from 245/75R16 to 265/70R17. I would think for a cummins it wouldnt make a big difference in taking off but when your cruising its less rotations to equal what you used to, so I'd see better milage when your cruising. But either way I doubt it drops the cummins more than a few mpg
Old 02-28-2007, 10:36 PM
finny's Avatar
finny
finny is offline
is it a good idea to put on 285/75's on my 01 dodge?
Old 03-01-2007, 12:58 AM
caytos's Avatar
caytos
caytos is offline
I'm running 315/70 17's. It will lower your mileage some. In the future I will probably run 285 or 305's. The 315's rub a little without a lift.
Old 03-01-2007, 01:56 AM
dixiedodge7369's Avatar
dixiedodge7369
dixiedodge7369 is offline
i put 35 12.5 17's on my 06 with just a level kit. no rub. PLENTY of room even doing some crazy articulation tests on snowbanks scaring the bajesus out of my girl.. and the people in the parking lot i was doing it in... id even say 37s would fit no prob... also i have NO milage drop
i was getting 15 16 ish before 15 16 ish now. same driving habits. soooooooo i dont know why people are losing 1-2 mpg im getting the same??? i just changed the manual tranny and trasfer case from factory atf+4 to royal purple syncromax.. ive only driven work to home 2 miles and it seems to shift alot better! well see if i get a milage increase????[8D]
Old 03-01-2007, 04:20 AM
Little Foot's Avatar
Little Foot
Little Foot is offline
I am running a 3" kit up front and 35X12.50 R17, with a 10" wide wheel I rub at the locks. I found that you will rubif wheels wider that 8" are used. Because of this I was able to sell my wife on a 6" superlift for my ride. Will post pics after complete.
Old 03-01-2007, 05:10 PM
Mayfair's Avatar
Mayfair
Mayfair is offline
ORIGINAL: CutterW
That's exactly what I did as well. The mileage may have dropped off, or my speedo may now be off, but either way they look a heck of a lot better than the ole 245's did.
Old 03-01-2007, 05:54 PM
MrSlug's Avatar
MrSlug
MrSlug is offline
I went with 305 65 R17's. The Speedo reamains accurate and I have notice no drop in MPG. Unless of course I use Stage 3 or higher for raped ape mode.
Quick Reply: Taller tires=more or less mileage on the CTD?
