Nice 2 hrs @ the stealer!
Old Mar 1, 2007 | 01:11 AM
bert0168's Avatar
bert0168
Default Nice 2 hrs @ the stealer!
So I was at the stealership today to get some options turned on and my ECM reflashed for fuel mileage issues. Here is how it went:
There is a TSB (18-037-04) "Fues economy improvement, White smoke on start up, Accuracy of fuel mileage in Overhead console display" This is for 2004-2005 5.9L CTD engines serial # 57130285 to 57246361 manufactures from 12/10/03 to 8/17/04
This is supposed to give you an MPG improvement of 1 MPG [&o]and stop white smoke on cold startups below 50 deg F. We'll see about the MPG improvement with my next full tank though I went in today getting about 10.5 per gal[:@]
I also asked to have the high idle turned on which the said they did but I can't seem to get it to work. Is it Truck on+in Park+Cruise on then push Set and it pushes it up to 1000 rpm? I tried it this eve and couldn't get it on.
I asked to have the Power on with Key off option activated and first the service rep asked me what the he!! that was then the tech claimed he couldn't find it in the computer module. Anybody have any ideas on this one?
Lastly I asked to NOT have the horn safety crap put on if it came up. Rep said it was no problem to leave that off if it came up.Tech came back and saidthe option had been previously turned off, meaning it was on there before I purchased it new and then was removed. So that crap about not being able to turn it off appears to be just that, crap.
All this I had done for $80 (did I say itWAS at the stealership) and I only got one out of three completed unless I am operating the high idle wrong.
Old Mar 1, 2007 | 03:15 AM
SpLaT's Avatar
SpLaT
Default RE: Nice 2 hrs @ the stealer!
bert0168, to get the high idle to work set cruise control "on" then hit the "accelerate" button to go from 1000 to 1500 rpm.
Old Mar 1, 2007 | 04:57 AM
gtxpooch's Avatar
gtxpooch
Start the truck, push cruise "ON" then push "SET" it should immediately go to 110 rpm.
Old Mar 1, 2007 | 02:23 PM
usafr's Avatar
usafr
The high idle thing is kindascrewy. When I activate mine with my Bully Dog, both times it didn't work right off. Then suddenly it started working. I would just bring it back and have them do it again and see what happens.
Old Mar 1, 2007 | 03:24 PM
DBLR's Avatar
DBLR
If the dummy was to look on his star tool he could find the Power on with Key off option to have it activated, I know as I had it turned on in my 2006 a long with the high idle that works with the cruise control. If they say they set high idle it should work in either park or N so long as you don't have your foot on the break. If it does not then they my of not turned it on as mine works the first time I tried it before I left the dealers parking lot.
Old Mar 1, 2007 | 03:27 PM
dave_thunderroad's Avatar
dave_thunderroad
well when i purchased my truck it does it automatically????when its real cold and im sitting in park at idle it will go up and if i hit the brake or whatever it just goes back to its normal self..
Old Mar 1, 2007 | 03:37 PM
DBLR's Avatar
DBLR
ORIGINAL: dave_thunderroad
All CTD have a self high idel. What we are talking about is a manula high idel that you can turn on with the cruise control and adjust the engine speed from 1,000 to 1500 RPM's any time you want while parked.
Old Mar 1, 2007 | 04:01 PM
firemansdodge's Avatar
firemansdodge
My truck high idle kicks in about 8-10 min in park. Goes from 700 rpm to 1100.
Old Mar 1, 2007 | 04:03 PM
cumminalong's Avatar
cumminalong
All of them have the auto high idle, this is for warm up purposes. The manual high idle must be enabled by the dealer and is used to power PTO accessories or to get extra juice from the alternator for accessories like winches.
Step 1 - Have it enabled
Step 2 - Vehicle must be in park or neutral w/ parking brake on. If it's in park it does not need the parking brake
Step 3 - Turn the cruise control on
Step 4 - Hit the set button. This will jump your RPM's up to 1100.
Step 5 - Use accel button to bring RPM's up. Use decel button to bring RPM's down. The lowest it will go is 1100.
Step 6 - Turn it off by either stepping on the brake, tuning the cruise control off, or putting the vehicle into gear.
Old Mar 1, 2007 | 04:56 PM
Mayfair's Avatar
Mayfair
ORIGINAL: cumminalong
Even the 2nd gens ??
