Rokk timing sensor
Old 03-21-2007, 02:55 PM
DBLR's Avatar
DBLR
DBLR is offline
Default RE: Rokk timing sensor
ORIGINAL: cumminalong
ORIGINAL: Drew
the retarded timeing for the EPA is a NOx issue. just giving two degrees does increase NOx emissions, but you also increase fuel mileage since the engine is burning the fuel more completely.
Hehehe! So does removing the cat.
OK, guess I need to [sm=wakeup.gif] how does taking the cat off help increase mileage?
Old 03-21-2007, 03:51 PM
Drew's Avatar
Drew
Drew is offline
it wont realy increase mileage, but the NOx emission will be higher. . .and you get that wonderfull diesel aroma back
Old 03-21-2007, 11:19 PM
NickBeek's Avatar
NickBeek
NickBeek is offline
ORIGINAL: Drew
Don't you wish they made an after shave O de diesel exhaust?
Old 03-22-2007, 02:37 AM
jakeman711's Avatar
jakeman711
jakeman711 is offline
That sound likea good mod. I would like to get one but I am affraid that I wouldn't know how to install it? I have never set the timing on a diesel. Is there a certain way to put it in and hoow to adjust the timimg, or is it a simple bolt on and go. Also, does it cause damage to the engine when you are pulling. I am new to diesel mechanics and I know in a gas job if you advance it too much and pull with it she will detonate. Fell free to pic on me. -Jake
Old 03-22-2007, 04:04 AM
handymanherb's Avatar
handymanherb
handymanherb is offline
I'm new to diesel's and it was a piece of cake, you just order a Rokk sensor and get some blue lock-tight and in 15 minutes you will be done.
Remove one MM allen screw, pull out the crank sensor then remove the connector, plug in the Rokk put lock-tight on the screw reinstall pushing up on the sensor and your done.
Old 03-22-2007, 05:14 PM
DBLR's Avatar
DBLR
DBLR is offline
My understanding is that Cummins had to set the timing back a few degrees to make the EPA happy and by doing this to the timing we got poor mileage but lower NOx emmisions. So by setting the timing back up 1-2 degrees we will get the fuel to burn better and get better mileage.
Old 03-23-2007, 03:30 AM
handymanherb
My question is, If the Rokk put the timing back where it use to be, why is there a warning about idling long times when cold and a they said it might be louder at idle but I haven't notice it making anymore more noise than before I installed it
Old 03-23-2007, 04:16 AM
gtxpooch's Avatar
gtxpooch
gtxpooch is offline
It is a little louder during cold starts. It says if you notice the knock, push on accelerator a little and it will go away when the ecm changes fueling parameters. I don't idle mine more than about 10 min. and drive slow for the 1st couple of miles then the knock dissapears. Just out of curiousity, is anybody using the rokktek and the xillaraider xzt?
Old 03-23-2007, 08:30 PM
joepascoe19's Avatar
joepascoe19
joepascoe19 is offline
im using the xzillerator adjustable module and the roktech timing sensor and havent had a problem yet
and it idols the same in the cold wether too its been anywhere from -25 to 30 above too
Old 03-23-2007, 09:16 PM
gtxpooch's Avatar
gtxpooch
gtxpooch is offline
joe, has it helped the mileage?
Quick Reply: Rokk timing sensor
