Acronym list
Old Mar 21, 2007 | 03:06 AM
gtxpooch's Avatar
gtxpooch
Default Acronym list
I've been searching and can't seem to find a list of definitions for the diesel parts. I'm trying to learn what they are. Anybody got a list?
Old Mar 21, 2007 | 04:28 AM
htgriffith's Avatar
htgriffith
Default RE: Acronym list
ABBREVIATION
DEFINITION
11916D
11 9/16" Diameter
15QT
1.5 Quart / 1.4 Liter
1QT
1 Quart / .95 Liter
1-SPD
1-Speed
203EC
2-03 Engine Calibration
2-DR
2-Door
2-PIN
2-Pinion
2QT
2 Quart / 1.9 Liter
2WD
Two-Wheel Drive
2WD4AT
Two-Wheel Drive with 4-Speed Transmission
2WS
Two-Wheel Steering
3-DR
3-Door
3-SPD
3-Speed
4-DR
4-Door
4-PIN
4-Pinion
4-SPD
4-Speed
4WD
Four-Wheel Drive
4WS
Four-Wheel Steering
5-BOLT
5 Lug Bolts on Wheel Hub
5-DR
5-Door
5DRATAC
5-Door with Auto Trans without Air Conditioning
5MT
5-Speed Manual Transmission
5-SPD
5-Speed
6-BOLT
6 Lug Bolts on Wheel Hub
6-SPD
6-Speed
8-BOLT
8 Lug Bolts on Wheel Hub
975D
9 3/4" Diameter
AA
American Axle
ABBR
Abbreviation
ABO
Above
AC
Air Conditioning
ADBV
Anti-Drain Back Valve
ADD
Automatic Disconnecting Differential
ADJ
Adjustable
ADRD
AF
Air Filter
AFL
Air Filter
AFRI
Air Filter Restriction Indicator
AL
Aluminum
ALCS
Aluminum Case
ALHB
Auto-Locking Hubs
ALUM
Aluminum
AMER
American
AMT
Automated Manual Transmission/Transaxle
AOT
Automatic Overdrive Transmission
ARC
Aluminum Rocker Arm Cover
AT
Automatic Transmission
AT/TX
Auto Transmission/Transaxle
ATF
Automatic Transmission Fluid
ATT
at
ATTS
Active Torques Transfer System
ATXL
Automatic Transaxle
AVC
Aluminum Valve Cover
AWD
All-Wheel Drive
BBL
Barrels
BCPN
Brake Caliper pins
BEG
Beginning
BEL
Below
BF
Before
BKC
Brake Calipers
BREA
Breather Element
BRK
Brake
BSYS
Brake System
BW
Borg Warner
C&C
Cab & Chassis
CA
California
CAL
California
CAN
Canada
CARB
Carburetor
CAT
Catalytic
CC
Cruise Control
CCNV
Catalytic Converter
CD
Code
CDIFF
Center Differential
CFBS
Clutch Fork Ball Stud
CH
Chassis
CHAS
Chassis
CHEV
Chevrolet
CHG
Change
CID
Cubic Inch Displacement
CK
Check
CLCB
Club Cab
CLNT
Coolant
CLTCH
Clutch
CNT
Connector
COCL
Cold Climate
COMM
Command
CON
Conical
CONAFWD
Conical Air Filter with Dome
CONAFWOD
Conical Air Filter without Dome
COND
Conditioning
CONV
Convertible
CPE
Coupe
CRCASE
Crankcase
CRKAF
Crankcase Air Filter
CS
Limited Slip
CSS
Limited Slip
CSYS
Cooling System
CVJ
CV Joint
CVT
Continuously Variable Transmission
CYL
Cylinder
D
Diesel
DCL
Decal
DD
Digital Dash
DEX
Dual Exhaust
DFT
Dual Fuel Tanks
DIA
Diameter
DIFF
Differential
DIRIGN
Direct Ignition
DOHC
Dual Overhead Cam
DP
Deep Pan
DRLN
Driveline
DRW
Dual Rear Wheels
DSL
Diesel
EB
European Built
ECT
Electronic Control Transmission
EFP
External Fuel Pump
EGR
EGR
ELAT
Electronic Automatic Trans
ENG
Engine
EOIL
Engine Oil
EPP
Extra Performance Package
ESSOORU
Except Severe Service or Off-Road Use
EST
Electronic Spark Timing
EV
Every
EVCT
Electronic Variable Control Transmission
EX
Except
EXT
External
EXTCAB
Extended Cab
EXTD
Extended
EXX
Except
FDIF
Front Differential
FE2
FE2 Suspension Package
FED
Federal
FF
Fuel Filter
FFT
Fuel Filter
FHUB
Front Hubs
FI
Fuel Injection
FINDR
Final Drive
FITT
Fittings
FLNG
Flange
FLSEN
Flow Sensor
FLSH
Flush
FLX-FL
Flex Fuel
FM
From
FMETER
Fuel Meter
FPCOND
Flat Pipe Condenser
FRT
Front
FSP
Fuel Saver Package
FSS
Flexible Service System
FWD
front-wheel drive
FWV
Foam Wrap Version
GL5
GL-5
GVWR
Gross Vehicle Weight Rating
HA
High Altitude
HBK
Hatchback
HC
Hot Climate
HCT
Hydraulic Control Transmission
HD
Heavy-Duty
HD4
HD4 Emission Package
HD5
HD5 Emission Package
HDEM
Heavy-Duty Emission Models
HDLG
Handling
HDLT
Headlights
HFNT
Hi-Flow Non Thermactor, And After 30,000 Miles
HH
Hex Head
HM
Hydra-Matic
HO
High Output
HSG
Housing
HW
Highway
HYD
Hydraulic System
ICOOL
Intercooler
IDT
IDI Turbocharger
IFP
In-Tank Fuel Pump
INCL
Include
INN
Inch
INT
Internal
INT'L
International
ITSD
IDI Turbocharger Super Duty
JPBLT
Built in Japan
KC
King Cab
LBED
Longbed
LBS
Pounds
LD
Light-Duty
LDEM
Light-Duty Emission Models
LDIFF
Locking Differential
LF
Leaded Fuel
LIMO
Limousine
LNG
Long
LPG
Liquid Propane Gas
LSD
Limited Slip Differential
LUB
Lubricate
LUBE
Lubricant
LWB
Long Wheel Base
LWR
Lower
MA
Maine
MAX
Maximum
MAXE
Maximum
MAZ
Mazda
MECHFI
Mechanical Fuel Injection
MET
Metric
METTON
Metric Ton Package
MEXP
Mexico Production
MF
Methanol Fuel
MHSG
Metal Housing
MI
Miles
MIN
Minimum
MINOIL
Mineral Oil
MIT
Mitsubishi
MIZ
Mizer
MO
Months
MOD
Model
MT
Manual Transmission
MT/TX
MTD
Mounted
MTG
Mounted
MTXL
Manual Transaxle
N
No
NBCK
Notchback
NE
North East
NLAX
Non-Locking Axles
NO.
Number
NR
Not Required
NV
New Venture
NVELEC
NV 136, 236, 246 electronic
NY
New York
OC
Overrunning Clutch
OCOOL
Oil Cooler
OCOOLER
Oil Cooler
OD
Overdrive
OE
Original Equipment
OFC
Oil Filler Cap
OFLT
Oil Filter
OHC
Overhead Cam
OOP
Optional Oil Pan
OPT
Optional
OPTWHL
With Optional Wheels
ORAP
Off-Road Air Package
OTH
Others
OVER
Over
OZ
Ounce
PA
Pulse Air
PANL
Panel
PBH
Plug Bolt Head
PCV
PCV
PCVS
PCV System
PCVT
Positive Crankcase Vent Tube
PERF
Performance
PGRIL
Painted Grille
PHP
Performance & Handling Package
PHSG
Plastic Housing
PKG
Package
PL
Plastic
POL
Police
PROD
Production
PSHF
Propeller Shaft
PST
Power Steering
PTO
Power Take Off
PTU
Power Transfer Unit
PWR
Power
RACVR
Rocker Arm Cover
RAI
Ram Air Induction
RALLYV
Rally Van
RARRC
Racing Regular Radiator Cap
RASRRC
Racing Safety Release Radiator Cap
RCA
Rear Carrier Assembly
RDHL
Round Headlights
RDIF
Rear Differential
REC
Recommended
RECHL
Rectangular Headlights
REDUCT
Reduction
REGCAB
Regular Cab
REMCOV
Removable Rear Cover
REQD
Required
RG
Ring Gear
RKC
Regular & King Cabs
RND
Round
RP
Regular Pleats
RPCOND
Round Pipe Condenser
RPKG
Rally Package
RRC
RUB
Rubber
RWD
Rear-Wheel Drive
RWHLS
Rear Wheels
RWIB
Rear Wheel Inner Bearings
SBED
Shortbed
SCHR
Supercharger
SEC
Sectional Case
SECOND
Secondary
SED
Sedan
SEL
Selec-Trac
SELDR
Select-Drive
SEQ
Sequential
SER
Series
SERV
Service
SFT
Single Fuel Tank
SGRX
Saginaw Axle
SHT
Short
SLC
Side Load Case
SP
Shallow Pan
SPCAB
Sport Cab
SPCH
Sport Chassis
SPD
Speed
SPDMT
Speedometer
SPPERF
Special Performance
SPT
Sport
SPVAN
Sport Van
SQH
Square Head
SRRC
SRW
Single Rear Wheels
ST
State
STD
Standard
STL
Steel
STR
Steering
SUS
Suspension
SVC
Steel Valve Cover
SYNTHOIL
Synthetic Oil
SYS
System
SZZX
S
TA
Trans Am
TCD
Torque Converter Drain
TCHR
Turbocharger
TCON
Traction Control
TEMP
Temperature
TEMPS
Temperatures
TENS
Tensioner
THRD
Thread
TLC
Top Load Case
TOD
Torque On Demand
TOPC
Top Cover
TORQ
Torque
TP
Tall Pleats
TRANS
Transmission
TRC
Transfer Case
TSAC
Top Shift Aluminum Case
TSIC
Top Shift, Iron Case
TT
Trailer Towing Package
TURBO
Turbocharged
TXL
Transaxle
UF
Unleaded Fuel
UJNT
Universal Joints
UOT
Underhood Oil Tank
UPR
Upper
UPT
Up to
USBLT
Built in USA
VANDURA
Vandura
VF
Variable Fuel
VR
Vapor Return
VS
Vapor Separator
W/
With
W/E
With Extension
W/O
Without
W3&35AT
With 3" or 3 1/2" Axle Tube
W7RG10BC
With 7 1/4" Ring Gear & 10-Bolt Cover
W7RG10BC2AT
With 7 1/4" Ring Gear, 10-Bolt Cover & 2 1/2" Axle Tube
W7RG2AT
With 7 1/4" Ring Gear & 2 1/2" Axle Tube
W7RG9BC
With 7 1/4" Ring Gear & 9-Bolt Cover
W7RG9BC2AT
With 7 1/4" Ring Gear, 9-Bolt Cover & 2 1/2" Axle Tube
W8RG3AT
With 8 1/4" Ring Gear & 3" Axle Tube
WAG
Wagon
WAG5MTAC
Wagon W/ 5-Spd Manual Transmission & Air Conditioning
WARC
With Aluminum Rocker Arm Cover
WB
Wheel Bearings
WC
Warm Climate
WGN
Wagon
WH
Wheels
WHBS
Wheelbase
WK6
WK6, External EGR Valve
WSRC
With Steel Rocker Arm Cover
YR
Year
Z19
Z19 Sport Package
[align=left][/align]
Old Mar 21, 2007 | 10:56 AM
Drew's Avatar
Drew
CARB also stands for California Air Reserve Board. . .A.K.A. pinko commie bastagaes.
Old Mar 21, 2007 | 11:59 AM
Watermelon's Avatar
Watermelon
ORIGINAL: Drew
WELL SAID !
Old Mar 21, 2007 | 01:51 PM
gtxpooch's Avatar
gtxpooch
Thanks!! That will help,anybodygot one for diesels?
Old Mar 21, 2007 | 03:09 PM
Hiloram's Avatar
Hiloram
Good thing that was the abbreviated list lol
Old Mar 24, 2007 | 08:22 AM
htgriffith's Avatar
htgriffith
HOPE THIS MIGHT HELP PEOPLE WANTING PACKAGE CODES OR INFO
*M9 - Cloth 40/20/40 Prem Bench Seat
-D5 - Med Slate Gray
ADA - Light Group
AF3 - Quad Cab Thunder Road Value Group
AHCP - Trailer Tow Group
APAS - Monotone Paint
BAZS - 136 Amp Alternator
BCQP - 750 Amp Maintenance Free Battery
BRTS - Anti-Lock 4-Wheel Disc Brakes
CBEP - 40/20/40 Split Bench Seat
CGDS - Front Height Adjust Shoulder Belts
CG1S - Next Gen Multistage Front Air Bags**
CKES - Front Seat Area Carpet
CLES - Front & Rear Floor Mats
CSPS - Passenger Assist Handle
CSXP - Rear 60/40 Split Folding Seat
CUES - Rear Underseat Compartment Storage
CUSS - Overhead Console w/Trip Computer
CVHP - Front Center Seat Cushion Storage
CVN - Folding Flat Load Floor Storage
DGBS - All 4-Speed Automatic Transmissions
DG8 - 4-Spd. Automatic 48RE Transmission
DMES - 3.73 Axle Ratio
DRQP - 11.50 Rear Axle
DSA - Anti-Spin Differential Rear Axle
ETH - 5.9L HO Cummins Turbo Diesel Engine
GACS - Tinted Glass Windows
GFDP - Rear Sliding Window
GNCP - Sun Visors w/Illum Vanity Mirrors
GNKP - Rear View Auto Dim Mirror
GNMS - Passenger Side Sun Visor w/Mirror
GTSS - Power Heated Mirrors, Fold-Away
GVBC - All Vehicles W/Power Mirrors
GXMS - Remote Keyless Entry
GXXS - Sentry Key Theft Deterrent System
HAAS - Air Conditioning
HGBS - Dash Liner Insulation
HGFS - Floor Tunnel Insulation
JAYS - Instrument Cluster w/Tach
JBYS - Instr. Panel Color Keyed Bezel
JCBS - 120 MPH Primary Speedometer
JHAS - Var Intermittent Windshield Wipers
JJAS - Cigar Lighter
JJBS - Dual Note Electric Horns
JJJS - 12V Auxiliary Power Outlet
JKYS - Power Accessory Delay
JPBS - Power Locks
JPDS - Power Windows, Driver One-Touch
JRDP - Power Driver Seat
JTHP - Power 6-Way Driver Seat
K1XP - STRIPE/BADGE/MOLDING/COLOR
K17P - STRIPE/BADGE/MOLDING
LBCP - Glove Box Lamp
LBDP - Ash Tray Lamp
LCLP - Front Dome w/On/Off Switch Lamp
LDAP - Underhood Lamp
LMAS - Halogen Headlamps
LNJP - Fog Lamps
LPES - Cargo Lamp
MBFS - Bright Rear Bumper
MCMS - Body Color Upper Fascia
MCTS - Bright Front Bumper
MDAS - Front License Plate Bracket
MFDS - Bright Grille
MGAS - Ram's Head Badge
MHAS - Black Windshield Moldings
MTDS - SLT Badge
MWDS - Removable Tailgate w/Caliper Latches
MXBS - Front Air Dam
NAA - Federal Emissions
NFUS - 34 Gallon Fuel Tank
NHBP - Auxiliary Transmission Oil Cooler
NHMS - Speed Control
NHNP - Electronically Controlled Throttle
NMCS - Heavy Duty Engine Cooling
NZCP - Current Generation Eng Controller
PS2 - Bright Silver Metallic Clear Coat
QS2S - Bright Silver Metallic Clear Coat
RAAC - All Radio Equipped Vehicles
RAQ - AM/FM CD 6-Disc MP3 Radio
RCKP - Infinity Speakers
RDDP - Fixed Long Mast Antenna
RDZP - Steering Wheel Mounted Audio Ctrls
RSAP - Sirius Satellite Radio
SBAS - Power Rack and Pinion Steering
SCVP - Leather Wrapped Steering Wheel
SFBS - Front Heavy Duty Shock Absorbers
SGBS - Rear Heavy Duty Shock Absorbers
SHAS - Front Stabilizer Bar
SUAS - Tilt Steering Column
TBBS - Full Size Spare Tire
TBMS - Tire Carrier Winch
TT3S - LT265/70R17E BSW All Season Tires
TZHP - Michelin Brand Tires
WF1S - 17" Steel Spare Wheel
WGDP - 17X8.0 Forged Aluminum Wheels
WLZC - All Aluminum Wheels
WMJP - Center Hub
XA8S - Non Adjustable Pedals
XBSS - Pickup Box
XCZP - Toluca Painted Cargo Box
XEAP - Tow Hooks
XFHP - Hitch - Class IV Receiver
XFKP - 7 Pin Wiring Harness
XFUS - Trailer Tow w/4-Pin Connector Wiring
XGWP - YES Essentials(R) Seat Fabric
X9AP - For More Info, Call 888-539-7474
X97P - 1-Year Service Provided by SIRIUS
YAAS - Build To U S Market Specifications
YG4A - 5.5 Additional Gallons of Diesel
ZCRP - Spring - Left Rear
ZFGP - Spring - Left Front
ZRRP - Spring - Right Rear
ZUGP - Spring - Right Front
Z2CP - GVW/Payload Rating
1AAS - U.S. Dealer Retail
166S - Zone 66-Orlando
2TGA - Customer Preferred Package 2TG
2UG - Customer Preferred Package 2UG
39JA - Thunder Road Value Group Discount
42EP - SALTILLO TRUCK ASSEMBLY PLANT
5B3 - Cargo Box Tracking
5IFS - DH-Vehicle Family
5I2S - Two Wheel Drive (2WD)/(4X2)
5ZES - 6 1/2 FT. Cargo Box
5ZKS - Quad Cab
5ZMS - 2500 GVW
Old Jul 4, 2010 | 10:08 PM
dale hanna's Avatar
dale hanna
Cool mega cab 2500 06 fault code
hey guys i have a 06 mega cab 5.9l with 60k miles have code on it P1740 off my super chips prog, also says TCC OR OVD SOL PERF(any ideas)
