Tow/Haul mode switching
Old Mar 25, 2007 | 09:32 PM
PRam's Avatar
PRam
Default RE: Tow/Haul mode switching
ORIGINAL: cumminalong
ORIGINAL: Barry KC
I have a '05 2500 series CTD with auto/OD. and 3:73 gears Even when pulling 12 to 14 K, I just leave the trans. in D. The one exception is if starting out in real hilly terrain. That engine has so much grunt, that it just does not seem to matter and I detect no strain on the trans.
Like I was saying.....the good thing about T/H mode is that it locks your TC in 3rd. This helps to lessen the heat buildup. It also holds 4th gear longer before downshifting......again, helps with the heat buildup.
That is the real reason i was asking was the heat buildup and the wear on the clutches in the tc during lockup.
just got back in town and the truck pulled it effortlessly like I new it would.
I would love to have known the tranny temp.I know the engine did not vary much, even having to pass some tard accelerating up a hill, on the right, because they didn't know how to get out of the left lane on the interstate[:@]
paul
Old Mar 25, 2007 | 10:45 PM
cumminalong's Avatar
cumminalong
ORIGINAL: PRam
paul
The only time you get wear on the clutches during lock-up is if they are slipping. For instance, on my Attitude I can monitor the slippage. It will de-fuel if it senses slippage.
The only times I notice slippage and back-down is if I have it turned up a bit and I hammer it from a stop, especially if the T/H is off. With the T/H engaged, the TC grabs much more noticeable and lock-up is a lot firmer.
Old Mar 25, 2007 | 11:19 PM
Watermelon's Avatar
Watermelon
Sounds like Dodge got the bugs worked out for you on the CTD?
Old Mar 25, 2007 | 11:51 PM
cumminalong
ORIGINAL: Watermelon
Oh yeah! She runs like a demon now. [sm=drooldude.gif]
Then again, the only thing that is still original on my truck is the body and the VIN. Everything else from intake to tailpipe and pretty much everything electrical has been replaced.
Now it's time to see what "I" can break.
