Dodge Ram SRT-10 The best claim to fame. the world's fastest production pick up, the Dodge Ram SRT-10. With outstanding Viper inspired styling, power and handling, this sport pick up will blow the doors off anything that gets in it's way.
SRT-10 injector 2,4,6,8,10 not firing
Old Dec 28, 2018 | 09:33 PM
Largecar389's Avatar
Largecar389
Default SRT-10 injector 2,4,6,8,10 not firing
Injectors 2,4,6,8,10 not firing.
ignition/spark is OK.
PCM checked it OK by Viper Store
whats wrong?
2004 Dodge Ram SRT-10
Old Dec 29, 2018 | 09:14 AM
Are the injectors getting power? PCM grounds them to fire them. (and I think it fires them in pairs?)
Old Dec 29, 2018 | 11:07 PM
Largecar389
Default Ugghh
so yes, I’ve just checked the injector voltages
the even numbers are now within the same voltages as the odd numbers... between 19.6 and 20.2 volts. Engine was warm- 200 degrees coolant and 165 degrees oil.
Engine does lose power when injector wires are individually disconnected, so it seems they are firing now.
still cannot get coded to erase
Old Dec 29, 2018 | 11:30 PM
Largecar389
Default Fixed
Aha!
tried the “disconnect reconnect” the battery thing one more time....
and No CODES!!! Yea me!!!
I’m an old school guy when it comes to cars/trucks, when comes to these darn electronic computer everything vehicles I struggle with it..... but, the Viper truck is back to doing what it’s supposed to do.
cheers
Old Dec 30, 2018 | 08:21 AM
I think you need to have a look at your charging system. You should only be seeing around 14 volts at the injectors, engine running.
Old Feb 10, 2020 | 12:05 PM
Simonhyde's Avatar
Simonhyde
Same problem..
did you solve the issue? I have cylinders 2/4/6/8/10 all off
Old Feb 11, 2020 | 01:03 AM
Largecar389
Default Solution
Odd number or even number injectors NOT firing—-
if you are showing power getting to the injectors, but injectors not firing
check your grounds. Engine to body, body to frame, etc.
turns out my grounds were bad, therefore injectors on one bank not firing.
pcm checked ok, wiring pcm to injectors ok, coils ok.
grounds not making contact.
clean grounds, all is well.
Old Feb 11, 2020 | 03:51 AM
Simonhyde's Avatar
Simonhyde
Thank you for the advice.. the passenger side loom looks close to the headers so I might remove the full harness and check for any damage..
loom removal looks quite a big job?
