Dodge Ram SRT-10 The best claim to fame. the world's fastest production pick up, the Dodge Ram SRT-10. With outstanding Viper inspired styling, power and handling, this sport pick up will blow the doors off anything that gets in it's way.
Ram SRT-10 Do It Yourself information
Old Jan 13, 2007 | 02:39 PM
CarGuyOhio's Avatar
CarGuyOhio
Default Ram SRT-10 Do It Yourself information
Click for Ram SRT-10 DIY.
DIY's are supplied by you, our members! If you would like to add a DIYPM the DIY to HammerZ71or94rt10ohio
Old Dec 3, 2008 | 06:03 PM
cali04srt10's Avatar
cali04srt10
Hey, how you doing? Thanks again for the advice on the truck, it has been up and running like a beast since I replaced the coils. I'm stationed in nc and drove it to florida for the thanksgiving day weekend and had no problems with it, and it did pretty good on fuel as well (20 mpg). Thanks again for the advice
Old Dec 11, 2008 | 07:29 PM
CarGuyOhio's Avatar
CarGuyOhio
Anytime.
Old Apr 8, 2009 | 11:28 PM
Midnight Runner's Avatar
Midnight Runner
Default Nitrous
Has anyone installed nitrous in a
SRT10? Thinking of doing it this
Weekend.
Old May 4, 2009 | 01:23 PM
cali04srt10
Default 4 cylinder missfire
Hey 94Rt10OHIO, how have you been? Well I find myself with another problem and I hope you can help me out again. My truck threw a check engine light and when I retrieved the code found out it was a cylinder 4 missfire code. I know I have spark going to that cylinder, but I still need to check compression and one of the only things I can think of is a plugged injector. I pulled the spark plugs and they all looked normal ashy except for number 4 which looked like it had a coat of gunk on it. What do you think? I hope you can help me out on this. Thanks
Old May 5, 2009 | 07:15 AM
CarGuyOhio's Avatar
CarGuyOhio
Either the plug, ingnition wire or coil is bad. Start with the plug as the wires terminate under the intake where the coils are located, in other words the intake has to come off to do wires and coil.
Make sure to clear your codes after putting in a new plug, I would also stick with the same Champions that are in your truck unless you are going FI.
Old May 5, 2009 | 10:25 AM
cali04srt10
Default Cylinder 4 missfire
Good morning, thanks for the info. I replaced the plugs and had the codes reset but the same code came back several miles later. I checked for spark at that cylinder and there definitely is spark going to that cylinder. I also ran a compression test on that cylinder and compared it with others and they were pretty even. I replaced the coils less than a year ago, and the only thing i could think of is a clogged injector. What do you think? As always thanks for your help.
Old May 18, 2009 | 01:20 PM
cali04srt10
Default #4 cylinder missfire
Hey 94rt10ohio, how are you? Well here I am again, after replacing the spark plug wires on my truck and clearing the code, the same code comes right back, and that #4 plug is still fouled after driving it several miles. I am starting to worry that it could be something worse, I will run another compression test on that cylinder later. On the positive side those plug wires are awesome, I was a little skepticle about them but I was amazed to see how much difference in resistance there was between the factory and msd wires. Thanks for the advice.
Old Aug 25, 2009 | 03:19 PM
TSIRE's Avatar
TSIRE
Default Clutch question
I have a 2006 srt10 and for some reason when i push down on the clutch it feels soft and wont go into gear; can anyone help me out? a friend of mines told me that it might be my clutch cable and if so where is it located and is it an easy fix?
Old Dec 17, 2009 | 07:49 PM
hanover606's Avatar
hanover606
i have a 2000 extended cab dakota 4x4, v8 magnum. i was wondering how and if i could make it a srt racer
