Dodge Ram SRT-10 The best claim to fame. the world's fastest production pick up, the Dodge Ram SRT-10. With outstanding Viper inspired styling, power and handling, this sport pick up will blow the doors off anything that gets in it's way.
shifting problems?
Old Mar 14, 2007 | 12:05 PM
OCHUCK88's Avatar
OCHUCK88
Default shifting problems?
The other night i was drinving and the went to put in reverse and it would not go in. Just woundering if anyone had this problem before with the 6 speed tranny? RC srt -10
Old Mar 14, 2007 | 02:42 PM
Midnight Runner's Avatar
Midnight Runner
Default RE: shifting problems?
I have not had a problem with my truck and it a 6 speed to.
By the way wlecome to D.Forum. Hope you like it.
Old Mar 14, 2007 | 03:15 PM
QUICK_SILVER's Avatar
QUICK_SILVER
There's alot of moving parts in that there 6/speed manual trans. They don't always mesh as soon as we would like them to do.
You will have a refuseal every once in awhile....never under W.O.T.!
I fine letting the clutch out half way and trying it again,always works.
Now with that said, if there is something wrong with your tranny or clutch, then your problem will get worst, and you'll know.
Quick
Old Mar 14, 2007 | 03:17 PM
QUICK_SILVER
And Welcome to the board!
Quick
Old Mar 14, 2007 | 03:26 PM
OCHUCK88's Avatar
OCHUCK88
I tried letting the clutch out half way and tried again and then went forward and then tried it again and again and again then finally went.
Old Mar 14, 2007 | 04:20 PM
CarGuyOhio's Avatar
CarGuyOhio
1. Your clutch could be going out
2. Possibly bleeding your system may help
3. Possibly replacing your fluid with a HIGH HIGH temp fluid and bleeding could help
Old Mar 14, 2007 | 04:35 PM
OCHUCK88's Avatar
OCHUCK88
i will try to bleed the clutch and if that doesn't work then i will try the high temp fluid thanx.
Old Mar 14, 2007 | 05:55 PM
QUICK_SILVER
ORIGINAL: OCHUCK88
You don't have the year of your Tuuck in yoursig. The '04's had a problem with the clutch-fluid line being to close to the header. They put a heat/shield over the line and put it up and away from the header-pipe.
Quick
Old Apr 10, 2007 | 10:11 PM
MADDOGC5's Avatar
MADDOGC5
my 04 had the 6th gear syncros go bad and 2 weeks ago my dealer replaced the trans with a new one...and yes i was having problem getting it into reverse too...
