Brake and Anti Lock ligths are on.
Old Sep 18, 2004 | 03:44 PM
marstang's Avatar
marstang
Default Brake and Anti Lock ligths are on.
I just bought a 1990 Dodge Ram Van 250. The Brake light and the Anti Lock warning lights on the dashboard is always on. It happened when the fuse for the cigarette lighter blow up. I changed the fuse, then the lights started to shhow. The Van runs excellent. Can I reset this? How can I reset the lights,
Old Nov 7, 2004 | 01:43 AM
xmax1's Avatar
xmax1
Default RE: Brake and Anti Lock ligths are on.
On top of the rear differential there's an electrical sensor (ABS / Wheel speed sensor). Replace it!! I'm willing to bet that the cruise control is inop also.
Old Feb 28, 2006 | 02:24 PM
marstang's Avatar
marstang
Sorry. The Cruise Control is working. Anyway, this new thing happens now along with this problem. Check engine came on. Check the error and stated: 37/---- PTU SOlENOID
Old May 19, 2006 | 06:41 PM
marstang's Avatar
marstang
Since the cruise control works, I went ahead and changed the ABS sensor that's on top of the differential. the lights did not go away. HELP
Old May 20, 2006 | 01:45 AM
xmax1's Avatar
xmax1
Check the fuse for the ABS. I believe there's actually 2 of them. It's been a while since I've worked for Dodge. Anyway, I believe the fuses are located in the PDC under the hood. Feel free to email me if I can help anymore ( xmax76@hotmail.com )
Old Jan 22, 2007 | 01:01 AM
$1.00 Ram Van's Avatar
$1.00 Ram Van
My van has the same problem, and I'd be thankful if it were just blown fuses. What is a PDC??
Old Jan 22, 2007 | 10:01 PM
xmax1's Avatar
xmax1
ORIGINAL: $1.00 Ram Van
The PDC is the "Power Distribution Center". If you look under the hood, there's a black box with a cover on it. it'll also have a wire leading from the battery to it. That is where all the wire harnesses get their power.
Old Jan 22, 2007 | 10:07 PM
xmax1's Avatar
xmax1
ORIGINAL: marstang
So did you find out what the problem is/was?
Old Jan 23, 2007 | 08:40 AM
IGadget's Avatar
IGadget
You can try clearing the trouble codes by disconnecting the negative battery terminal for about 30 seconds and seing what comes back. Aslo this may seem silly for the ebrake light, but pull up on the ebrake. you my be getting a false indication from the switch that it located on the ebrake itself.
