Just Joined from U.K, Help needed on Van.
Old Jun 9, 2007 | 08:01 PM
3pinplug's Avatar
3pinplug
Default Just Joined from U.K, Help needed on Van.
Hi,
I have a 1979 Dodge B200 fitted with a 318, am looking to check the timing but a previous owner has painted over the emissions label under the hood. Can anyone tell me what the timing should be BTDC or ATDC, also do I check it with the vacuum advance pipe on or off.
Thanks
Mark
Old Jun 10, 2007 | 01:25 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Default RE: Just Joined from U.K, Help needed on Van.
You're screwed![sm=noooo.gif]The repair manual says to refer to the underhood sticker.
Traditionally the 318 ran anywhere from 2.5 BTDC to TDC at full warm up, 750 RPMs, distributor vacuum hose removed and plugged.
Try working within this range and adjust as necessary to avoid pinging.
