Lower Hinge Pin
Old Sep 7, 2007 | 07:17 PM
TomBrooklyn's Avatar
TomBrooklyn
Default Lower Hinge Pin
The lower hinge pin on the drivers door of my '89 B250 has worn out. Is this a common problem on these vans?
Old Sep 7, 2007 | 08:32 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Default RE: Lower Hinge Pin
It can be a problem on any 18 year old vehicle.
Old Sep 14, 2007 | 02:52 PM
Dodgevanman's Avatar
Dodgevanman
Just think of how many times that door has opened and shut since 1989. My 72 van has saggy doors.
Old Sep 14, 2007 | 09:25 PM
stev's Avatar
stev
Hey DVM, good to see you over here too.
Anyways, in the Ram Van forums around the web lately, people are all talking about the pins being worn out.
The hardest part is either getting new pins or getting the old ones out.
Old Sep 21, 2007 | 03:14 PM
shdbriding's Avatar
shdbriding
Getting the pins shouldn't be to bad. If they are the same as the ones in an '87 b150.
Help section at local auto parts store part number 38386 door hinge pin and bushing kit. They might have to order it for you. Comes with pins for top and bottom and four brass bushings.
You may however have to replace the whole hinge depending on how long its been bad. The holes in my lower hinge were egged out a little bit and the bushing moves around slightly but it opens and closes 100% better.
