Loosing anti freeze
Old Dec 29, 2007 | 10:04 AM
davedawe's Avatar
davedawe
Default Loosing anti freeze
318,5.2, 1999, 3500 van
800 miles had to add, no leaks showing on ground, note anti freeze smeal,twice
Where to look for leaks? Thanks
Old Dec 29, 2007 | 01:16 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Default RE: Loosing anti freeze
A blown head gasket will draw AF into the cylinder and burn it off. This problem usually causes wisps of white smoke (steam) out of the exhaust. Check the exhaust for white smokeafter the engine has been fully warmed up and driven for a few miles.
Old Dec 30, 2007 | 07:03 AM
davedawe's Avatar
davedawe
Thanks for reply
Yes I see some white smoke from exh., small amount.
Cost to fix,replace gasket,1999,5.2L.?
Would I do damage, driving 800 miles home?
Oil pressure,coolent temp shows normal.
Old Dec 30, 2007 | 10:22 AM
alloro's Avatar
alloro
About $100 to fix it yourself or about $600 for a shop to do it. Driving with a blown headgasket is a time-bomb waiting to go off. There is no way to know when it will get to the point of being undrivable. If you keep a good supply of water and AF mix with you and make sure the level doesn't get too low, you'll have a 50/50 chance of making it. Babying it will increase your chances of making it, while beating on it will reduce your chances. Overheating is your biggest enemy right now, because even if you make it, an overheated engine can leave you with warped heads and an even larger repair bill.
Old Jan 3, 2008 | 08:39 AM
davedawe's Avatar
davedawe
Yesterday,I had the Dodge dealer,check AF problem, get cost for fixing.
They completed a pressure test on coolent systems, no problems found.no leaks.
No AF in oil, had oil change.
Old Jan 3, 2008 | 10:24 AM
alloro's Avatar
alloro
Is it just me or does common sense dictate that if there aren't any problem with the cooling system then you wouldn't be losing AF?
