Transmission Fluid
Old Sep 19, 2010 | 03:08 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by rcallihan
4. Also mentioned in other posts: "If you're dropping the pan and changing the filter as well, then the low/reverse band needs to be adjusted while you're in there. That is, if you want to save yourself a trannyrebuild job down the road." I am not clear what this is and if it is something I can do myself. Can anyone provide more detail?
Read up...
https://dodgeforum.com/forum/dodge-r...tml#post798923
