how to remove engine on a 95 b150W3.9L
i never seen it done on one of these, probably should get a book, but figured id ask, looks like it can be done a few ways, pull the core support, lift the body off the frame(what i think i want to do if its really possible),pull frt subframe and suspensionandremove from bottom(hard for me to do with out a lift). any info on what is easiest any pics? what can and cant be done? thanks, ....David
RE: how to remove engine on a 95 b150W3.9L
My preference is to remove the radiator and grill and pull the engine out the top front. Taking it out the bottom can be a bit tricky because of the way you have to slide the engine back as the body is being lifted. Plus, if you take it out the top, you don't have to remove the tranny.
