odometer and engine code 35 fault
Old Aug 17, 2008 | 12:42 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
The one thing the instructions did not cover is that there is a wire bundle over the top left side of the cluster, on my van it blocked me from just pulling out the cluster, I had to gently pry the bundle up to get the cluster to come towards me. If when pulling yours and it seems to be stuck then check for the bundle and be carefull when removing and installing the cluster unit.
Old Feb 4, 2009 | 04:49 PM
roberson's Avatar
roberson
Default odometer and engine code 35 fault UPDATE
I finally got around to ordering the gear for my odometer. Thank you Leeann and Mobile Auto Repair for you advice. It took me less than an hour per both of your instructions and it works like a charm now.
Earlier this Fall I had my A/C checked out and it turns out that it's an $800 fix, so no luck on that but I was wonding if anyone knew how to bypass the wide open throttle cutout relay so the my engine fault would go away. The a/c repair is just too expensive for me to justifiy it.
Thanks for all your help again!
roberson
Old Feb 4, 2009 | 11:53 PM
Leeann's Avatar
Leeann
Great! I'm glad you got it fixed.
