94 b350 acts as if out of gas. No ignitionlight
Old Aug 6, 2008 | 11:27 PM
slo's Avatar
slo
New Member
Default 94 b350 acts as if out of gas. No ignitionlight
My 94 b350 5.9 van coasted to a stop as though the feul pump had died. I then notice that the ignition light would no longer function . The van has 80k miles on it so I ruled out the fuel pump.Then I went looking for a fusable link.
After pokeing around on the dang ole internet I'm thinking perhaps it's a faulty smec or a relay of some kind .Anyone have any input before I start spraying parts at this thing.
Old Aug 7, 2008 | 02:15 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
I would first check out the ASD relay on the firewall near the brake booster, to make sure it's working.
Old Aug 7, 2008 | 06:06 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
I do not understand about the "ignition light would no longer function". Are you meaning the "check engine" light?
After checking the ASD relay I would see what codes the PCM has, those may tell you what the computer needs.
The fuel pump can go bad even though it only has 80K for it is now (if original) 14 years old. I would check the fuel pressure, you can also listen as you turn the key to the "run" postion and see if the pump runs for about 2 seconds.
I would also check for spark at the spark plugs.
Old Aug 7, 2008 | 06:51 PM
slo's Avatar
slo
New Member
Thanks guys, Yep I meant check engine light.
Since thats not working I am unable to capture the codes.
I have only verified that 12v. is present to the relays ( I'm not sure wich one is wich just yet)
Old Aug 7, 2008 | 11:20 PM
Mobile Auto Repair
Do you know anyone with a diagnostic tool that can read the OBD-I series computers? If so then they can hook up to your PCM and pull the codes.
If the light quit working at the same time the van died I hope that the PCM did not die. Did you check the fuse that goes to the PCM, it may be blown.
Old Aug 8, 2008 | 10:48 AM
slo's Avatar
slo
New Member
Thanks again, yep , The dealer is happy to check the codes for 175$
The check engine light dowsed st the sme time the egine conked out.
I replaced the relays and have ordered (shudder) the pcu..(200$ at advance)
it should be here Tue.
Old Sep 4, 2008 | 04:54 PM
slo's Avatar
slo
New Member
Default I may set this thing on fire
Well where to start ?Oh ,Iknow I'll start at the end.My van still will not run.
After verifing that the computer connector had voltage and both grounds.That continuity existed between smec and asd, fuel pump and coil.
I went out and bought a second rebuilt smec .
Still no check engine light,fuel pump, no spark
I,m very nearly beat.
Old Sep 4, 2008 | 05:29 PM
alloro's Avatar
alloro
Did you verify if there's voltage on the output side of the ASD and fuel pump relays while the key is in the ON position?
Old Sep 5, 2008 | 12:19 AM
slo's Avatar
slo
New Member
yes ,there is no voltageon the output side of asd or fuel pump.
Old Sep 5, 2008 | 09:51 AM
alloro's Avatar
alloro
There is a 30 amp fuse in the power box under the hood that feeds power to both of those relays. I believe it's fuse #1. If that fuse is blown you won't get power to those circuits.
