A/C compressor relay '88 dodge b250 van
Old May 3, 2009 | 01:53 AM
italian dodger's Avatar
italian dodger
Talking A/C compressor relay '88 dodge b250 van
Someone can give me a photo of the A/C compressor relay.(mounted)
where it must be, in my van ther'is the LPG pump... and i'd like to find it because my a/c compressor is every on whit motor on (the a/c control, max pressure sensor,ecc.. work all propely) and I think is the relay always on.
sorry for very bad english
Gian
Old May 4, 2009 | 05:56 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
No compressor relay in 88. The wire for the compressor clutch comes right off the selector switch in the dash. Take the switch out of the dashboard and disconnect the single orange wire. If the compressor does not run with the orange wire disconnected then the switch is bad and must be replaced.
Old May 5, 2009 | 06:24 PM
italian dodger
my problem is that the a/c compressor is every on with the key turned on!
also with the pressure valve disconnected is on!
the maintenace book make see a relay near the engine, under the windscreen (parabrezza)
Old May 7, 2009 | 06:52 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
If it is on even with the heater/ac control switched off you may need to cut the hot wire (+) wire at the ac compressor and route it into the dash and put a switch in where you can turn it on and off as you wish to.
Old May 11, 2009 | 04:42 PM
italian dodger
ok, i yet start this work, but i'd like the system works with the sensor (presssure )
How I can make to be sure the original swich control work or not?
the orange wire is 12V/0Volt or an open/close concact?
the compressor is on also with all wire disconnected on the original swich control!!!!!!!!!!!!!! (the wire on compressor is Black, right?)
thanks
Old May 11, 2009 | 09:10 PM
alloro's Avatar
alloro
The black wire goes to ground. The dark blue with a black stripe wire comes from the control switch in the dash. Here's the diagram I have for 1988.
Old May 12, 2009 | 04:10 PM
italian dodger
thank's alloro. the diagram is little different by the diagram that i have.
saturday i try again.
bye
gian
Old Sep 6, 2010 | 10:55 AM
linton's Avatar
linton
how do take out my a/c compressor in my 1998 dodge status, as my bearings are making an awful noise when i start it. I am going to put a a/c bypass pulley on!
Old Sep 6, 2010 | 12:49 PM
alloro's Avatar
alloro
Umm...unbolt it?!
Old Sep 6, 2010 | 09:43 PM
Mobile Auto Repair
And up plug it plus disconnect the hoses going to it. On this car you may have to take it out from underneath the vehicle.
