1996 van 3500 Cant comminicate with computer
Old Jun 17, 2009 | 03:59 PM
salesbig's Avatar
salesbig
Question 1996 van 3500 Cant comminicate with computer
1996 dodge ram van 3500
The check engine light is on. When they mechanic try to hook up the computer there was no communication
Any thoughts?
Old Jun 17, 2009 | 05:03 PM
kev2's Avatar
kev2
remote starter, yes-no?
have you checked ALL fuses, under dash and under hood?
there is not a "no buss" message is there?
try the scanner on another vehicle-
OBD connector. probe with DVOM
top row 1-8 driver door is 1
bot row 9-16 driver door is 9
CK Pin 2 - J1850 Bus+
CK Pin 4 - Chassis Ground
Pin 5 - Signal Ground
Pin 6 - CAN High (J-2284)
PiN 7 - ISO 9141-2 K Line
Pin10 J1850 Bus
Pin 14 - CAN Low (J-2284)
Pin 15 - ISO 9141-2 L Line
CK Pin 16 - Battery Power
SOMETIMES THIS WORKS ...
Turn the ignition key until the digital odometer displays, repeat three times in succession and then back to "On" (On/Off, On/Off, On/Off, On). At the fourth "On" the odometer will be replaced with codes. If no codes are present then "Done" will appear.
Old Jun 17, 2009 | 06:36 PM
salesbig's Avatar
salesbig
no digital od. no bad fuses. no remote start.. ill check the pins..
thanks.
just in case this doesnt work.. anyone else have any ideas?
Old Jun 18, 2009 | 08:32 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
If the fuses are good, you either have a broken wire issue or a bad computer.
Old Jun 21, 2009 | 07:25 PM
salesbig's Avatar
salesbig
Computer seems to be good, i disconnected the battery, re-connected and the check engine light came off. then 15 miles later it came back on..
Anyone know how to check the wires? any pictures of how the wires run from the obd female connector to the computer?
thanks
Old Jun 21, 2009 | 07:37 PM
salesbig's Avatar
salesbig
thanks
Old Jun 21, 2009 | 07:57 PM
alloro's Avatar
alloro
Any thoughts?
Any chance your mechanic's code reader is no good, or that he was using an incorrect cable?
Old Jun 22, 2009 | 07:47 AM
salesbig's Avatar
salesbig
No.. i even bought one for myself.. he tried 2 units..
Old Jun 22, 2009 | 07:55 AM
kev2's Avatar
kev2
i posted the obd connector pinouts above.
check that bat+ and ground pins..
lets be clear - no communication? is not the same as not showing code..
removing battery willnot clear codes they are still in memory
Old Jun 22, 2009 | 08:59 AM
salesbig's Avatar
salesbig
removing battery will not clear codes they are still in memory
when you disconnect the battery the check engine light went off. came back on about 5 miles later. So im thinking the computer is good.
So if im wrong please let me know.
