My heat blows warm air please help
Old Jan 5, 2010 | 06:37 PM
zanko79's Avatar
zanko79
Originally Posted by alloro
Um, this is probably a bad time to ask, but what year is your van?
1997 b2500
Old Jan 5, 2010 | 07:15 PM
zanko79's Avatar
zanko79
Originally Posted by zanko79
I only removed glove box and linkage rod is on left side, it does moves with hand but when i moved my air stops blowing.I can't see motor do i have to take off all the front panels i guess.
Linkage rod does move when i switch beetwen floor, vent bi-level or heat but when i move lever betwen cold or hot it doesnt move linkage rod.It only blows cold air.What does selector beetwen cold and hot does?
Old Jan 5, 2010 | 08:25 PM
zanko79's Avatar
zanko79
YES I have my heat finnaly, problem was on selector beetwen hot and cold it wasnt closing blend door inside heater box located under hood passenger side.Something wrong with linkage wire so i just closed it manualy with screwdriver it works.Thanks for all your help
Old Jan 5, 2010 | 08:55 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Linkage rod does move when i switch between floor, vent bi-level or heat but when i move lever between cold or hot it doesn't move linkage rod.
That's the wrong linkage rod. That one is for selecting where the air comes out. It is not the one to move the blend door. Maybe these pictures will help.
Take a look at #2 in the second picture, that's the linkage rod you want. It comes through the firewall and connects to the #1 lever in the first picture and is held in place by clip #6.
Old Jan 5, 2010 | 11:04 PM
stev's Avatar
stev
It's possible that the electrical actuator is dead or the wires are damaged going to it. The part is made by Johnson Electric / Saia-Burgess. The part may be marked CEI on the casing. The part is made in the USA and is sold via the dealer.
Old Jan 6, 2010 | 07:20 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Zanko79 as the number 2 picture in Alloro's post above shows the blend door on our vans is under the hood in front of the heater core. Easy way to test is have some one slide the cold/hot lever back and forth as you look under the hood. You will see where the cable is and where it is attached should move one way for cold air and the other way for hot air. If the blend door is moving then you may either have a plugged hot water shut off valve (if you have a van with AC) or a restricted heater core. You can try if the blend door does move to adjust where the blend door arm attaches on the cable to see if you can manually move it further to the hot side.
Old Jan 7, 2010 | 12:59 PM
zanko79's Avatar
zanko79
That's exactly what i did find out (You will see where the cable is and where it is attached should move one way for cold air and the other way for hot air).I did moved it manualy it works not the best but it does works for know.I guess probally there is also a problem with heat core (cloged up) but since i live in Atl GA i will live it like this.Thanks to all for your help again
