Wiper Blade not working
Old Dec 31, 2009 | 05:26 PM
ASAP's Avatar
ASAP
Default Wiper Blade not working
I have a 98 Dodge Ram Van and the wiper on the driver's side decided to stop working. The weird part about it is that if i lift the wiper off the windshield, it turns normally, without a problem. As soon as i place it back down so that i can actually use it, it stops working. Any idea??
Thanks!
Old Dec 31, 2009 | 08:43 PM
master tech's Avatar
master tech
Site Moderator & Tech
There could be a problem with wiper links or the wiper arm is striped.
Old Jan 1, 2010 | 06:13 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
I agree with this. It does sound like the wiper shaft is turning inside the wiper arm when there's no load on it.
Old Jan 1, 2010 | 07:31 PM
ASAP's Avatar
ASAP
ok, and how would i go about fixing that?
Thanks!!
Old Jan 1, 2010 | 09:50 PM
HoosierDaddy's Avatar
HoosierDaddy
That depends on the color of the stripes on the wiper arm.
Old Jan 2, 2010 | 12:10 AM
alloro's Avatar
alloro
Remove the wiper arm and inspect both the wiper shaft sticking out of the hood and the hole in the wiper arm. There should be fine splines on each. If either one is smooth you'll need to replace it.
Old Jan 2, 2010 | 12:11 AM
alloro's Avatar
alloro
Say what???
Old Jan 2, 2010 | 12:46 AM
ASAP's Avatar
ASAP
ya i know about the splines... but how do i take off the arm? i dont want to just pull it i was worried to brake it....
Thanks!!
Old Jan 2, 2010 | 08:24 PM
HoosierDaddy
Originally Posted by alloro
Say what???
ASAP . .
On the bottom segment of the arm, (where it might be stripped) either there's a small silver clip on the topside that can easily be pried upward at the same angle as the windshield with a screwdriver, just enough to release it (nearly ¼") allowing you to lift the whole arm directly off of the shaft. You'll need to lift the wiper blade up off the winshield a couple of inches or more to release the clip-lock in order to slide the clip upwards. The clip is affixed to the segmented base of the arm itself so don't worry, you won't lose the little thing. It slides up with the arm. Just remember to slide the clip back down into place once you've replaced it.
OR
There's most likely a small set-screw in the same proximity (usually directly under the arm) you'll need to loosen enough without removing it to remove/replace the arm in the same manner as the clip method.
Hope this helps.
