02 B1500 ignition problems, please help
Old Feb 15, 2010 | 04:56 PM
jwburg's Avatar
jwburg
Default 02 B1500 ignition problems, please help
I have been having problems with my dodge van for 2 months. It always ran perfect, then 1 day I took it to the car wash, and it died. Started right back up, and didn't really worry about it. Then 2 weeks later, it wouldnt start. I didnt do any tests, I just changed the ignition coil. It started right up, and I didnt think about it again until a week ago when it wouldnt start again. This time I checked for spark on the main lead coming from the coil. It was intermittent. I disconnected the battery and reconnected it and it was fixed. Drove it for another week with no problems, then, in the morning, wouldnt start. I checked the forums and figured I would change the ignition pickup coil. That fixed it for another week. And here we are today. I checked the forums again, and cleaned all the grounds under the hood, and checked for 12v+ between the neg post on the battery and the wires going to the coil. Got nothing. And now Im stuck. Please help....Thank you
Old Feb 15, 2010 | 06:24 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Bad ASD relay, ignition switch, or PCM.
Old Feb 15, 2010 | 11:08 PM
master tech's Avatar
master tech
Site Moderator & Tech
The dist cap could also be wet inside. That will cause a no start problem too.
Old Feb 17, 2010 | 09:04 AM
jwburg's Avatar
jwburg
Default checked dist cap
I checked the distributor cap, it is dry and newer with no corrosion. i dont know what the asd relay is. are there any tests to determine which part is bad before I keep replacing.
Old Feb 17, 2010 | 12:10 PM
alloro's Avatar
alloro
The ASD relay is in the power box under the hood. Try swapping it with another one under there for testing purposes.
Old Feb 17, 2010 | 01:55 PM
jwburg's Avatar
jwburg
Default No luck.
Swapped the ASD relay with the AC relay, still no spark. there are no DTC's. Im starting to get frustrated. I dont want to take it to the mechanic, he is just going to replace parts until it runs again....
Old Feb 17, 2010 | 01:56 PM
jwburg's Avatar
jwburg
how do i check the ignition switch?
Old Feb 17, 2010 | 03:33 PM
alloro's Avatar
alloro
Since your problem is intermittent, the best thing you can do is hook up a test light to the ignition wire and drive around. When the engine quits, see if the light is on or if it died with the engine.
Old Feb 18, 2010 | 08:58 AM
jwburg's Avatar
jwburg
OK. Figured it out. When I got home from work, I took the dog house off and cranked it over just for kicks. I could see the coil, and there was a huge spark jumping from under the boot coming from the coil! Changed the wire and it runs perfectly. Thanks for all your help!
