need help!!
Behind the power brake booster there is a Fusible link. A blown fusible link will have burnt looking insulation and should stretch out. If you cannot find it, follow the fatter positive battery cable from the alternator o the battery. It will be inline with that.
"A fusible link is a short piece of insulated low-voltage cable within an automotive wiring harness that is designed to protect the harness in applications where a fuse is unsuitable. In an extreme current overload situation, the conductor within the link is melted while the ensuing flame and spark is contained within the link's insulation."
http://www.whiteproducts.com/fusible-faqs.shtml
Alloro has a nice Diagram about fusible links, and how to correctly replace one.
https://dodgeforum.com/forum/dodge-r...ssue-help.html (post #7)
