One more P0505 code....
Old Apr 21, 2010 | 01:03 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by dirtfisherrob
It hit 3 psi in about 20 seconds and I shut the engine down.
From the TSB:
NOTE: DURING THIS DIAGNOSIS, IT WOULD BE NORMAL FOR THE ENGINE TO DEVELOP PRESSURE WITHIN THE ENGINE CRANKCASE. THIS IS DUE TO -THE NORMAL PROCESS OF. EXHAUST BLOW-BY- GASES- LEAKING PAST THE ENGINE PISTON RINGS AND ACCUMULATING IN THE ENGINE CRANKCASE. DO NOT ALLOW MORE THAN 3 PSI (20.7 kPa) OF PRESSURE TO BUILD WITHIN THE ENGINE WHEN PERFORMING THE FOLLOWING DIAGNOSTIC PROCEDURE.
10. If the attached vacuum pressure gauge does not indicate that a vacuum is present in the engine crankcase, then the intake manifold plenum pan gasket is good and no further internal engine vacuum leak diagnosis is required.
Old Apr 21, 2010 | 01:05 PM
alloro's Avatar
alloro
the engine dies immediately. Is this normal?
Yes it's normal if you do it quickly. Try doing it real slow and the PCM has a chance to react and the engine won't stall.
Old Apr 21, 2010 | 02:25 PM
dirtfisherrob's Avatar
dirtfisherrob
Thanks alloro, I just had my nose fixed and now my eyes don't work so good! lol
So, at this point what would you guys recommend?
Old Apr 21, 2010 | 04:51 PM
dirtfisherrob
Originally Posted by alloro
From the TSB:
So because the gauge went to the right and not the left then i'm okay?
Old Apr 21, 2010 | 10:29 PM
alloro's Avatar
alloro
So because the gauge went to the right and not the left then I'm okay?
Yes, in going to the right you were getting pressure, not vacuum in the crankcase.
Old Apr 21, 2010 | 10:30 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Can you post a pic of your gage?
Old Apr 21, 2010 | 10:37 PM
alloro's Avatar
alloro
He did back in post #9 on page 1 of this thread.
https://dodgeforum.com/forum/2098211-post9.html
Old Apr 21, 2010 | 11:13 PM
Mobile Auto Repair
Ok, I missed that. That what I get for working 12 hours today. I feel like I have been hit by .
Old Apr 22, 2010 | 01:42 PM
alloro's Avatar
alloro
So why were you on the computer instead of spending some time with the wife?
(I had to ask, she paid me $20.)
Old Apr 22, 2010 | 10:10 PM
Mobile Auto Repair
LOL, we both like that. My wife said "YEAHHHHHH"!
