Differential Oil Capacity
Old Jun 21, 2010 | 02:30 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by lomita
BTW, STP was the 4 day LSD.
Only someone from California would've known that.
Old Jun 21, 2010 | 11:05 AM
lomita's Avatar
lomita
Default California?
Only someone like yourself would make that assumption......no one is from California, this is old Mexico...........everyone knows that!
Old Jun 21, 2010 | 02:12 PM
alloro's Avatar
alloro
Oh and in the upper right hand corner of your posts the "Location: California" is what, just a fashion statement?
Old Jun 21, 2010 | 10:48 PM
master tech's Avatar
master tech
Site Moderator & Tech
Dude you forgot about brownies.
Old Jun 22, 2010 | 07:01 AM
lomita's Avatar
lomita
Default Hey Walter
Right over your head dude......
Old Jun 24, 2010 | 01:46 PM
Rusty93RamVan's Avatar
Rusty93RamVan
@Landyacht318 - Just performing normal maintenance, no noise issue to overcome on my '97. Figured it would be best to use the Mobil1 synthetic oil even though the diff is standard (non-LSD) unit.
On my '93 I waited until I heard noise and by then it was too late to salvage the ring, pinion, pinion bearing & outer axle bearing surfaces.
Appears the gray silicone was factory, so diff oil was probably never changed unless it was done by a shop that used a vacuum tube to draw old gear oil out thru the access hole in the cover.
Seems quieter now with the Mobil1 in there but it's probably just my imagination.
@Alloro - I hope it's not the double-barrel purple microdots messing with me.
Old Jun 24, 2010 | 10:31 PM
alloro's Avatar
alloro
Oh great, just what the world needs, another tree hugging hippie.
Old Jun 25, 2010 | 09:37 AM
Rusty93RamVan
Brother, you got me all wrong. I'm a satellite dish installer and tree is a "four-letter word" in my business. This year on Earth Day I cut five trees down -- whatever it takes to get a line of sight for my signal.
And I'm so conservative it would probably scare you.
Old Jun 25, 2010 | 09:53 AM
alloro's Avatar
alloro
I was jesting.
Old Jun 27, 2010 | 02:23 PM
Rusty93RamVan
I was jesting.
I know.
