how big is the manifold gasket replace job?
Old Jun 30, 2010 | 07:41 AM
wilbo's Avatar
wilbo
Default how big is the manifold gasket replace job?
I'm thinking of replacing the manifold gasket on my 93' 318 (105k miles). I'm using more oil than I would expect and plugs are fouled so I suspect I may have a leaking gasket (or plenium?).
How big is this job and other than new gaskets is there anything else I need to have ready?
Wilbo
Old Jun 30, 2010 | 01:35 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
It's fairly straightforward. Disconnect some wires, fuel and vacuum lines, radiator hoses, the A/C-alternator bracket, remove some bolts, and off it comes. The plenum is on the bottom-side of the intake. Clean everything and reassemble. Give yourself about 4 hours to do it.
Old Jun 30, 2010 | 01:56 PM
wilbo's Avatar
wilbo
cheers Alloro, you da man
So weekend should do it, with interupts from wife accounted for heh
Wilbo
Old Jun 30, 2010 | 02:14 PM
alloro's Avatar
alloro
You might want to replace that little heater bypass hose and it's clamps while you have the intake off if it appears to be old or in rough shape. It can only be replaced when either the intake or water pump is off.
Old Jun 30, 2010 | 02:50 PM
wilbo's Avatar
wilbo
ah good tip. I've replaced a few hoses but only ones accessable without removing too much other stuff. is the thermostat get-at-able when doing the intake or is that a water pump one?
Old Jun 30, 2010 | 03:31 PM
alloro's Avatar
alloro
The t-stat is in the top of the intake, and yes, do yourself another favor and replace it when the intake is out. It's much, much easier that way to clean off the old gasket.
Old Jul 1, 2010 | 05:26 AM
wilbo's Avatar
wilbo
Shopping list is getting bigger
thanks for the tips Alloro
Old Jul 1, 2010 | 11:30 PM
stev's Avatar
stev
If you search the forums here, make sure you get a premium plenum gasket. This way you will not need to do the job twice or thrice in your life time.
Old Jul 2, 2010 | 12:04 AM
alloro's Avatar
alloro
Thrice?
Old Jul 6, 2010 | 06:29 AM
wilbo's Avatar
wilbo
Once will be enough for me
I usually get stuff from Rock, this one is coming up - any ideas if it's 'premium' FEL-PRO Part # MS95392
thanks
