Serp Belt Tensioner
Yes it can. I use a stethoscope or a length of wooden dowel and place one end on the center bolt of the tensioner pulley while the other end is next to my ear. (Next to it, not pointing at it!) This amplifies any noise the tensioner makes so you can confirm it as the source.
I have a '96 V10 - I am not sure that they are the same exact tensioner but they are all pretty much the same...
I was able to replace the pulley only - it was $16 verses like $60 for the entire tensioner.
And heads up - that bolt that retains the pulley to the tensioner is reverse thread....
Cool - thanks guys.
Follow-up....
I replaced the tensioner with a new Dayco unit this morning and all is back to normal. I didn't realize how much noise that old tensioner was making until I got the new one in there.
Something to note - my A/C compressor's clutch engages smoother now that the serp belt has the correct amount of tension on it.
Follow-up....
