eFan Installation Pictures
Here are a few pics of my electric fan installation.
This is a 16" generic fan mounted directly to the radiator. The factory shroud has been removed and discarded along with the factory metal fan & clutch assembly. New water pump, radiator, hoses, thermostat, radiator cap, and coolant have been installed.
Fan operation is controlled by a coolant triggered sensor, and I have a manual switch on the dash in case I wish to draw air over the A/C condensor to keep cool in traffic or on those slow back roads.
If you run into issues with the eFan not pulling enough air flow since the entire radiator core face isn't covered with a shroud, you might need to find your old shroud and put the eFan and motor mounted into it instead. Or if that shroud isn't anymore available, a few simple cut sheets of polypropylene and CPVC would be the ticket to make one easily by hand.
I do a lot of highway driving so the radiator sees 65MPH+ airflow across all vanes most of the time. Running in town at 35MPH creates just as much airflow as the most powerful eFan.
When you add the efficiency of the new aluminum radiator vanes versus the factory copper there's almost no way possible for me to overheat.
For Pennsylvaina, this is a great setup.
Back in 2005, I was towing through PA from Philly, to Lancaster, to York, to Gettysburg. For two days of the trip, the outdoor temps were over 100 that summer! Mine being a 2001 with the factory tranny cooler held up except after going up a steep incline on the interstate. I had to pull over and let it cool down. Other than that one time event, the cooling system has worked flawlessly.
Check out the condition of my old radiator after 13 years of service...
My fan shroud was the only thing holding the right radiator bracket together -- notice the nice collection of crap at the bottom!
Trending Topics
